Final bug in brake system, then back on the road.
Discussion in 'General Maverick/Comet' started by scooper77515, Jun 22, 2014.
  1. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Mine were also on correctly, the issue was the caliper bleeder wasn't pointing up causing air to remain in the lines.
  2. 71gold
    what calipers would have the bleeders pointing down when installed correctly?
  3. blugene
    Sounds like he didn't actually take them off just tilted them up more for bleeding.. :huh: But I still couldn't tell what caliper would do that. Maybe the bracket is not clocked correctly? :hmmm:
  4. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Sounds like you need the 2# resid valve in the rear line. What's happening is the pads are retracting after brake application, causing your first "pump" to take up this slack (that shouldn't be there). The resid valve holds the pads against the rotor so there's no wasted slack to take up.
  5. scooper77515
    I will try that e-brake trick first, then order a valve if it still has the lag. I just seem to be too busy to even go into the garage for 10 minutes to mess with the brakes...
  6. scooper77515
    Internet went out, so I couldn't get my work done. Went out and did the e-brake trick, but still goes down halfway on first pump, so I will order one of those valves.
  7. scooper77515
    Finally got a chance to install that 2 psi residual pressure valve. Seems to have fixed the problem! :dancing:
    Now if it stops raining and the roads dry up, I will take it for a test drive...
  8. 71gold
    now would be a good time to test it...:yup:
  9. 71gold
    got any installed pics?
  10. scooper77515
    Pic of the final setup at master cylinder.
  11. 71gold
    ...:Handshake...
  12. blugene
    I need to know which master cyl that is and which prop valve that is also..
  13. scooper77515
