Experience with electric fan. Help?
Discussion in 'General Maverick/Comet' started by Richard Kuss, Feb 10, 2017.
  1. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    Kept it. Works pretty well. The fan comes on half as much as when I had the stock radiator.
  2. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Rich
    The Taurus does not sat square or parallel to the radiator in the stock car . There a slight taper . you need to trim the taper out the shroud and move the as close to the radiator as possible . I used a corrugated paper about 3/16" thick
    as a set up spacer from radiator to fan blades for clearance and trim shroud to fit. There is pic in my gallery of how to trim the shroud. And you still may need to cut water pump shaft flush with pulley .
  3. Richard Kuss
    Richard Kuss Kusstum Fabrication
    Red Bluff Ca
    1970 Ford Maverick, 1970 Maverick parts car
    Champion 3 row. Between radiator and WP pulley I have barley 3 1/2 inches
  4. 71gold
    I ran their shroud and fan with no problems...(347)...:thumbs2:
    this pic is with LS motor installed...4" from fan to water pump...:yup:
  5. quickshift
    quickshift Member
    Ontario Canada
    71 comet/84 cougar
    I have a 3 row A/C rad with a trimmed Taurus fan and still have enough room.
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    At 65mph, the fan isn't accomplishing anything. You don't even need a fan at that speed.
    The fan is for low speeds and idling. There is obviously a problem somewhere else.
  7. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    Where did you get that radiator?
  8. quickshift
    quickshift Member
    Ontario Canada
    71 comet/84 cougar
    It was a Ford part # D2......... It was listed as a OEM rad for a 72 Comet with A/C. That rad is 40+ years old and still works fine.
  9. William623
    William623 Member
    Orlando
    you might want to look at one of these they come off the 1990s volvos. They run the same fan as the Taurus and the fan doesn't come with a shroud that has to be cut! From some rough measurements it looks like this will fit with a champion 3 core radiator. I am going to try it in a few weeks IMG_2149.JPG
    quickshift likes this.
