engine build
Discussion in 'Technical' started by burnout22624, Feb 12, 2012.
  1. burnout22624
    burnout22624 Member
    virginia
    76 Comet
    Want more power out of the 302 in my 76 , its all original with around 50k miles on it , is it worth putting h/c/i and a 4bbl setup on it or is the bottom end in those things not worth keeping?
  2. jm16
    jm16 Joe Marino
    Oak Park, MI
    1975 Comet GT
    Very worth it. Bottom end isn't a problem until you get into high horsepower
  3. burnout22624
    burnout22624 Member
    virginia
    76 Comet
    im just worried about compression ratio , id like the car to have at least 300hp to the wheels if possible
  4. jm16
    jm16 Joe Marino
    Oak Park, MI
    1975 Comet GT
    302 bottom end handles 300 hp easily. Your comp is probably 8:1 and what you want to do isn't going to hurt that. Biggest issue you'll have holding you back is the stock heads. I think you are on the right track, many of us started by doing the same thing.
  5. burnout22624
    burnout22624 Member
    virginia
    76 Comet
    so do you think the edelbrock performer rpm top end kit would get me there or should i do a more custom setup with smaller cc heads?
  6. bmcdaniel
    Biggest problem is the D4 blocks had an extra .020"-something deck height for very low compression. Small chambered heads and thin head gaskets can help raise compression and give better squish/quench distance. Also the timing chain sets from those years were retarded a few degrees.
  7. bmcdaniel
    The Edelbrock cams are over priced junk... Speaking from personal experience.
  8. burnout22624
    burnout22624 Member
    virginia
    76 Comet
    so from your experience what setup would you go with to have good power without touching the bottom end , also thought about converting to a roller cam as well but just a thought.
  9. bmcdaniel
    First decide what heads you want and build around them. To put a roller cam in your old block you either need a small base circle cam w/factory lifters (bad idea) or a full sized roller cam with expensive linked roller lifter (best way).
    What trans and rear gears do you have?
  10. jm16
    jm16 Joe Marino
    Oak Park, MI
    1975 Comet GT
    Roller cam will get pricey since you'd have to get a retro fit kit, as you start spending serious money, the stock head limitation sticks out as being a problem. Just my opinion of course.
  11. injectedmav
    injectedmav Member
    Georgia
    Ditto on the head restriction.
    If you're on a budget, start with what you've already mentioned, and don't overlook the exhaust .system.
  12. burnout22624
    burnout22624 Member
    virginia
    76 Comet
    stock c4 and rear right now
  13. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    74 Maverick street car 73 comet drag car 74 comet drag car
    Virginia Burnout
    Where you at in Virginia? Lets go racing know lot of combos on a budjet.
  14. Craig Selvey
    300 hp at the rear wheels? Don't plan on getting there without spending a bunch of money in my opinion. I don't see how one could do it without touching the bottom end.
  15. burnout22624
    burnout22624 Member
    virginia
    76 Comet
    im in winchester
    looks like i should of just stuck with my 03 mach 1
