Disk brake squeal
Discussion in 'Technical' started by Comet-73, Jul 1, 2006.
  1. scooper77515
    Personally, I use this trick. I just grind them on the concrete at a 45 degree angle, or thereabouts, as far down and close to the metal as I can. I do both leading and trailing edge, so I don't get squeal in reverse. Never have to mess with them again until time for replacement.
  2. Comet-73
    Comet-73 Member
    lethbridge AB Canada
    73 comet gt, 76 comet 4 door, 71 Maverick 200/I6
    Ill try that.. i went to the part store and to get some of those clips and they thought i was speaking a differnt language. They tried to tell me if they dont come on brand new pads they are not supposed to be there.... ill try a differnt parts store tomorow.
  3. scooper77515
    They aren't usually on all the pads, but when you buy set of 2, one will have it. Set of 4, 2 will have them. Install one pad with the wear-detector clip on each wheel. I think you typically install them on the inside of the two pads.
    Someone further up said the same thing, if I am not mistaken.
    Be sure you are shopping at a reputable or semi-reputable (NAPA, AutoZone, or better) shop. You shouldn't get blank stares on this...it is a normal, everyday item that anyone who has done or sold brake parts knows about, even if you describe it to them in vague terms, not knowing the correct terms and names. (I am not even sure if "wear indicator clips" is correct, but everyone knows what I am talking about. I think I have referred to them as "squeal clips" and they understood!)
  4. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    Is it one clip per wheel side?
  5. Blown74
    Blown74 Member
    Va
    74 302 blown- 68 Shelby Gt 500- 69 Cougar XR7 428 ram air
    squeal
    Also - just a thought - did you put a little moly grease in all the right spots? If the pad can't move they will get in a slight angle and make noise.
  6. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    Don't overlook my question, please. :dance:
  7. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    Yes one clip per side.
  8. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
    I put one clip on the top and another clip on the bottom of the inside pad, is this still ok?
  9. daydreamer
    daydreamer Mavmenace
    Oshawa, Ontario
    1972 Ford Maverick
    clips are supposed to go on the BOTTOM of the Inner pad. not on top.:tiphat:
  10. rayzorsharp
    Correct! Oh, and this is a very old thread! :cool:
