Cutting sheetmetal; what do you use?
Discussion in 'Technical' started by John B, Aug 4, 2006.
  1. maverick75
    Wish i had a plasma:cry:..got to use one once...made the job a whole lot easier...till i get enough money i'm stuck with the electric grinder...i've been putting away the floorboard job for so long...burned myself today with the grinder...but the exhaust sounded great:bouncy:
  2. 74merc
    74merc computer nerd
    1974 Comet
    I found the 3/32 wheels don't last too long, I use at least 1/8, much thicker than that and they don't last either.
    Of course I cut my floorpans, part of the cowl and all the fresh sheetmetal...
    if you can't hold your breath the whole time, a mask is nice too. It sucks to be blowing rust out of your nose 3 days after you cut clean shiney new steel.
  3. Mavaholic
    I have a plasma cutter but seldom use it on sheet metal. Cut off wheels leave a finished edge. Plasma cutters do not.
  4. John B
    John B Member
    Ontario, Canada
    '73 Mav
    Yesterday, when I posted this question, I also put up 2 other posts with questions on different subject matters. I got similar responses to all three; lots of excellent information and opinions! Just one of the reasons that this board is such a great place to hang your hat. Thanks tons fellas. John B
  5. Jamie Miles
    Alto, GA
    I've had a few
    Sawz-All, Angle Grinder with a cut off wheel, Die grinder with a cut off wheel, or a Dremel for real thin metal/small cuts. Just depends on where I'm at and what I'm doing/cutting.
  6. PaulS
    Panel cutter for long cuts with a single layer, Saws-all forcutting multiple layers. grinders generate too much heat and dust, plasma cutters are good if you have to cut thick metal that the panel cutter won't do and cut-off wheels for small jobs. I don't like to work at it too hard.
