comet running rough (help)
Discussion in 'Technical' started by mavmike72, Oct 5, 2008.
  1. blugene
    Ok. So you were watching the light flash rapidly... that eliminates a few things.
    Did you run the engine with the light pluged in? It would look like it was on steady...
    :scratchchin:
  2. mavmike72
    mavmike72 Member
    louisville kentucky
    Yes ....... But i just installed all new plugs again. I found a ground on the harness not grounded so i grounded it, took it out just no for a ride. Stomped the gas that thing had more power than its ever had. Then it happened it started serging again......
  3. blugene
    The only other thing I can think of at this moment is a bad diode in the alternator... or HP cam lol.
    My money is still on the cap...
  4. Mavman72
    Is it surgeing at idle or under power/cruise condition???
  5. LukeDuke
    LukeDuke Member
    Oklahoma City
    1976 Comet
    did you check the cap and rotor for corrosion?
  6. mavmike72
    mavmike72 Member
    louisville kentucky
    at idle when you punch it it goes.............
  7. mavmike72
    mavmike72 Member
    louisville kentucky
    well idle i mean you no crusing at about 30 just giving a little gas.
  8. Mavman72
    Gene raised a good point:thumbs2:Hows your charging system??? check the battery terminals make sure you have a good clean connection at both,If you have a volt meter check the battery voltage.A poor connection in the system will cause a voltage drop,which will limit voltage/amperage to vital components such as injectors/fuel pump/computer etc...
  9. mavmike72
    mavmike72 Member
    louisville kentucky
    ill check be back........................
  10. blugene
    He is saying that #6 is dead, then I understand a slight miss at part throttle while cruising...[​IMG]
  11. blugene
    Cap and rotor... cheap anyway if your going to throw parts on it. :)
  12. mavmike72
    mavmike72 Member
    louisville kentucky
    6 is not dead any more i guess last night when i replaced the injectors that fixed that. As far as the voltage checked the battery its 12.9 started the car and its 14.5
    so i guess its charging. Im pretty sure the miss is gone for now anyways.
  13. mavmike72
    mavmike72 Member
    louisville kentucky
    I put a new cap and rotor on as well.
  14. blugene
    So are you experiencing a dead spot when you go to accelerate while at part throttle while cruising?
  15. blugene
    When?
