changing efi
Discussion in 'General Maverick/Comet' started by rolandag2, Jul 7, 2007.
  1. rolandag2
    rolandag2 Member
    Dickinson, TX
    1970 Maverick Grabber
    I have my two engines at the machine shop and both are setup for low compression to run turbos. Having said that, I would like to get rid of my aluminum edelbrock heads and rockers and arp head bolts, and intake and computer. I going to use a different head (afr) and 1.7 rockers with studs and a custom built sheetmetal intake and fast efi computer to run turbo. I would like to get input On what you guys think they are worth. I will post pics also of the items.:)
  2. scooper77515
    Roland, you know you are ALWAYS supposed to call me first...
    I will give you $250 for all of it, and I will pay the shipping:D
    j/k, had to do that. Sorry. Probably worth much closer to $2500:yup:
  3. rolandag2
    rolandag2 Member
    Dickinson, TX
    i'm serious and:rofl2: bout the 250.00 yeah i would really like to get rid of this stuff to pay for the heads and fast system. I will building the intake myself(y)
  4. scooper77515
    I would like to see what you end up with. With your skills, I am sure you will end up with an original one-off well performing intake.
    Now that I think about it, probably anything you could build out of aluminum sheetmetal would be better than anything you could buy over the counter...Should flow ENOURMOUSLY!!!
  5. bmcdaniel
    I've seen the newer, 5-digit part number Ebrock heads go for $700-$800 used. The older ones with 4-digit part numbers don't fetch as much. If you get AFRs and the correct cam for your apllication you won't need 1.7 rocker arms.
