Center section
Discussion in 'Parts Interchange' started by Dean Deeter, Mar 22, 2006.
  1. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    Will a four bolt 8" center section go in a 5 bolt 8" rear end ? Dean
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Yes, the center sections are the same.
  3. don graham
    it's all the same til you get out to the ends of the axles. :)
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    All the good stock ratios were in 4 lug cars!
    Pintos, Bobcats, and M2s are great places to find cheap 3.40 and 3.55 gears.
    Some Rancheros had 3.28s, but those are O/T because they are 5 lug... ;)
    Dave
  5. Dean Deeter
    Dean Deeter Member
    Thanks guys for your help. I sure would like to find a 3.40 or 3.55 center section. How hard is it to replace just the gear and pinon. Thanks Dean
  6. Mercurycruizers
    Venetia, PA
    Takes alot of know how, to setup the ring & pinion. Need to chalk the gears & turn them, to make sure you have a nice even pattern. I just purchased the whole center section with the gears I wanted. Checked the pattern on the gears, best setup I've ever seen. Was worth the $500...
  7. Dean Deeter
    Dean Deeter Member
    Hey Coop, what ratio did you get?? If you don't mind what type of car did you get it out of. Also is this a cruiser or do you use it at the track or what? Have you had that ratio before and did you like the performance?? Dean
  8. 71gold
    dean,
    i got a 3:55 ring and pinion and a powertarx set up for $75 bucks. took it out and put a 3:00 back in...didn't like how tight the motor got on the hwy. at 70 MPH...frank...
  9. stmanser
    Davenport, Iowa
    i wanted to find some gears.. and spent a good part of a month looking... in arizona.. couldnt find crap... i have a set of 3.55 gears for an 8.8 if anyone is interested... i need a 3.80 gear set.. and a trak lok preferably... i am going to start looking for junkyards this weekend out here in davenport
  10. Dean Deeter
    Dean Deeter Member
    Stan, I noticed you have been looking for a while. What cars are you going to be looking at. Frank, I understand setting those up is a major job. I sure would like to find a center section already done. I have an extra 2.73 center section I would like to deal with for a higher ratio. Dean
  11. Mercurycruizers
    Venetia, PA
    I got the center section from, "puremuscleperformance", in Wilton, Calif. It is the older waffle case housing. I got the Torque Lock posi 3:80 gears. This rearend will handle up to 350 horsepower. I use my car as a cruiser & go to the drag strip a couple times a year. I've had 3:55 gears up until now. I haven't had a chance to test the 3:80's yet. The car has been in the shop for 6 weeks, getting all the suspension redone. Hopefully I'll get the car back tomorrow. I'll let you know what I find out as soon as I get it back....
  12. Dean Deeter
    Dean Deeter Member
    do you mind telling mr how much you paid for the section. Dean
  13. Mercurycruizers
    Venetia, PA
    I paid $510.00 With a one year limited waranty. So far, I'm impressed with it. You can probably find the guy on Ebay. I emailed him directly. I didn't go thru Ebay. I paid him via Paypal...
  14. goose
    goose Member
    Richmond BC
    comet 77
    what other cars can I look for parts ??
    Need a air pump for my 250 77 comet, what other cars could donate the pump I need ! any for sure help is appreciated , thanks !:bowdown: :banghead: :banghead: :bowdown:
  15. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    What does that have to do with the price of beans in Texas??...
