carb question
Discussion in 'Drag Racing' started by Country Mav, Nov 19, 2005.
  1. fordman
    fordman Member
    lufkin texas
    1972 maverick
    the one i have is a holley 600 HP got it from a carb shop on ebay for 165.00 had it on something but was to Small for them ---it looked new when i got it its a fine little carb
  2. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    go up two jet sizes in the primary,it isnt too big, worst case try a stiffer spring in the secondary
  3. maverick9611
    maverick9611 MEAN MACHINE RACING
    grovetown,georgia
    71 grabber
    try these guys. their prices are decent and the carbs work well. i have a 950 super mod and a 750 ho and that i've been using and have had no problems
    http://www.aedperformance.com/HO.htm
  4. TonyS
    TonyS Member
    Ventura Ca.
    1972 maverick grabber
    Kept the 750, it time to come out and play.
    1. First let check some easy stuff, check the holley mount bolts.
    2. Check the intake bolts.
    3. Dose the choke work? is it wired open? or is it hanging free?
    4.with the engine off, pull the site plugs front and rear fuel bowls. Dose the fuel just leak out when to rock the car. or dose it run out when you pull the site plugs this is inportant. You want it to just spill out when you rock the car.
    5. With the car off have someone floor the load peddle. check to see if the thottle is open all the way. With the load peddle floored try and move the carb linkage, if you adjust it. Then with load peddle floored try and open the vaccum secondary by hand. Do they fell smooth and open all the way?
    6. Pull the plugs ,how do they look? white ,tan, or black.
    7. Now let crank it let it wram up. Put a vaccum gage on it, look for 15-20 lbs.
    8. adjust your air mixture srews with the vaccum hook up then adjust each screw to the highest reading.
    9. Set the timming around 12.
    10, How is your fuel system? Good pump ?
    Kept us posted. The MAVMAN has sound advise.
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    This thread is 2 years old!:hmmm:
  6. valleyracer
    valleyracer Member
    Ottawa Canada
    1977 Maverick Drag car 399 engine,C4 trans,9"with 4.33 gear ET 10.25 @ 128 mph
    Some good info here though! I would have gone the other way with a .28 squirter to make the shot longer?
    Richard
