Carb main bodies
Discussion in 'Technical' started by Racer_X, Jan 4, 2010.
  1. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    That is why swapping baseplates can make your carb a different size.
    The bores in some models of carbs are the same, it's just the butterflies in the baseplate that are different.
  2. justin has a 74
    kentucky
    :16suspect i was just going to suggest summit.
  3. Mavman72
    I know Andy,just putting it out there.Not trying to step on your toes buddy :Handshake
  4. Andysutt
    Conway Arkansas
    1972 Comet GT
    No problem.. Just posting it to educate the un-knowing. :thumbs2:
    :Handshake
  5. baddad457
    And just to further confuse the issue, there is a single feed, mech secondary Holley, the old 660 centersquirter. And the center hung single feed Holleys were Ford carbs only I think. And there were single feed side hung VS Holleys with metering block on both ends. They just used a longer fuel transfer tube. Used to find these on heavy trucks mostly.
  6. Andysutt
    Conway Arkansas
    1972 Comet GT
    I was wondering about the single hung side hungs... I thought I had seen one, but I know they arent offered these days.
  7. baddad457
    The carb you now have would be worth more sold as is(if it's an O.E Ford Holley), then the money used to buy the smaller carb you want. That carb is a list 80783 650 cfm VS Holley. A 570 SA would also be an excellant choice.
