Broken lifter, but timing chain is good....help, help, help!!!
Discussion in 'New Members Forum' started by mrgreen187, Feb 29, 2008.
  1. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Rocker breaks, puts bind on cam, cam gear stops for a second, timing chain doesn't, due to slack in chain it jumps teeth on gear.
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I agree.
  3. mavron 70
    mavron 70 Member
    R.I.
    1970 maverick 5.0 t 5 trans 59 ford rear with 4.11 cogs
    say it's an exhaust valve rocker......cylinder will still get fuel but it's got no where to go because exhaust isn,t opening....if it does not hydraulic lock...guess it would have to go back up where it came from....
  4. jcshipp
    jcshipp Member
    bentonia ms
    74 grabber
    well thanx u guys. u just answered my problem. i got the same thing here. now i understand what happened. guess ill check the dizzy gear tomarow and get a new chain just to b on the safe side.. thanx agian. jeff
    :bowdown:
  5. Mavman72
    buy a double roller T-chain set.Dont cost much more than a standard one.Or at least get steel gears with the new one you do buy.The nylon geared ones are a waste of money.
