axle brace?
Discussion in 'Drag Racing' started by MaverickDan, Mar 7, 2014.
  1. MikeG747
    MikeG747 Member
    Arkansas
    Bottom hole worked best. Rancho shocks. Firmest setting. Stock Cal Trac mounting plates. Best 1.30 60ft.
      File size:
      94.3 KB
  2. John Holden
    John Holden Member
    NJ
    Great sixty foot times! I think most people end up using the bottom adjusting hole. The rancho shocks must come with a bracket for the bottom because my cal trac plates just have a single hole for a vertical bolt. Thanks for sharing your setup.
  3. John Holden
    John Holden Member
    NJ
    Oh I just looked at the picture and your cal trac plates are different than mine.
  4. MikeG747
    MikeG747 Member
    Arkansas
    These shocks came with my kit from Cal Trac so I guess that's why my plate is different!
  5. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    If you ever want to get out cheap on a stock 9in rear axle brace just heat & form a piece of 5/8 rebar & weld it on the back of the housing to the tubes & pumpkin.Not pretty,but tough as nails & you will NEVER bend it.
  6. murphy88
    murphy88 Member
    waterloo on
    73 maverick 76comet
    rebar
    Would this piece of rebar help out my 8" ??? .tnks
  7. John Holden
    John Holden Member
    NJ
    Beware of welding things to the axle housing. Unless done properly with a housing jig I can "almost" guarantee the housing will be warped using the amount of heat needed to properly weld any type of brace on.
