Any fuel injected mavericks out there?
Discussion in 'General Maverick/Comet' started by maverick70347, Nov 21, 2006.
  1. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I like the way Rick triangulated his.
    He's got them tied to the firewall, but it looks to have an angle that is less than desireable, so he also tied them to a Monte Carlo bar.
    That is how I would try to do it for best support.
    Mark:
    I used to know the exact dimension, but it has been 10 years...
    27.5" comes to mind, but I would be lying if I said I knew it was right.
    That could be the width of the Cleveland as far as I know nowadays. :huh:
    I know the stock braces would not line up proper.
    I portapowered the towers apart until they fit, then gave them a bit more for insurance. I put the engine in, and the braces fit like a glove when I was done.
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    i would measure mine but my shock towers are shaved so numbers are goin to be off
  3. ratio411
    ratio411 Member
    Pensacola
    Actually it won't be off if you measure from the top/center of one shock to the top/center of the other.
    My car is not here or I would try...
  4. eddie1975
    Martinsburg, WV
    sold
    i will be glad to measure it, i will first thing tomorrow its just started raining HARD, and other than being dark also.
    i never thought shock to shock:slap: i was thinking inside of tower:yup:
  5. ratio411
    ratio411 Member
    Pensacola
    Wonder if the stock braces would work with this intake?
  6. eddie1975
    Martinsburg, WV
    sold
    i would say yes, being that its skinny
  7. ratio411
    ratio411 Member
    Pensacola
    Probably shifts the power band quite a bit higher.
    The long runners of the top manifold are tuned for good torque.
    Shorter runners = better top end with lower torque loss.
  8. eddie1975
    Martinsburg, WV
    sold
    well let me show you dyno numbers from a supercharged 342 w/ this intake
    this is from one my friends mustang from last year:yikes: not bad for a street driven car :biglaugh: with 27 pounds of boost:D it did have 36 pounds but it was backed off
    the higher numbers below the circled numbers is what they were making , for some reason it was slippin of the dyno;)
    if you must know it was on pump gas :cool:
  9. Dave B
    I've bought everything I need to put EFI on my 73, now I just to find the time to pull the existing motor, drop in the roller motor with the AOD, and then start wiring...I can't wait!!
  10. eddie1975
    Martinsburg, WV
    sold
    here comes the good gas milage , overdrive and EFI:)
  11. Jamie Miles
    Alto, GA
    I've had a few
    I've been thinking about offering up some $$$ to my uncle for the '95 Mustang GT convertable my cousin totalled earlier this year. Relatively low mileage EFI 5.0 HO/5 speed with black interior. That drivetrain and parts of the interior would be awesome in my '69.5. Wonder if the entire dash and console would fit...
  12. eddie1975
    Martinsburg, WV
    sold
    nothin a torch and welder cant make:D
  13. Sam M.
    Sam M. Just a nobody
    Southern NJ
    Here's another... '95 Mustang roller block... All Ford parts... did it myself the hard way. Would I do it again? You bet!
  14. eddie1975
    Martinsburg, WV
    sold
    nice
    no shock tower braces? cant really see
  15. Sam M.
    Southern NJ
    Guilty as charged...:shhh:
