9 inch rear end questions
Discussion in 'Technical' started by primodemo916, Jul 5, 2016.
  1. primodemo916
    primodemo916 Member
    Sacramento Ca
    1970 Maverick Grabber
    Hi i have a 71 mach 1 rear end i believe to be a 2L75 9 inch that i want to put in my 70 maverick.. I have been researching and understand it is 5 inches wider then the stock rearend.. Is there any offset of wheel i could run so i dont have to cut the rear end down? Rolling fenders? I am running stock 67 mustang steel rims.. All advice and opinions welcome.. Thankyou
  2. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    How much horsepower do you plan on putting at the rear wheels ? What size Rear End is in
    your 70 Now ? Mine came with an 8" 4-Lug and I converted to 5 Lug and a Gear. Sometimes an 8" inch Maverick or Comet Rear End will suffice. No cutting , just Gear. JMHO . We have a 72 Maverick with a 347 Stroker and an 8" EquaLok. and it's holding up well, and a 70 Maverick 5.0 FI with an 8" inch with 3:55 Richmond gear setup (equalok) and it does fine.
    Cometized
    (Chip)
  3. primodemo916
    primodemo916 Member
    Sacramento Ca
    Im running a mild built 351w... I bought the car with the 7 1/4 rearend dont know if it was factory or not.. I got the 9 inch for a deal and its a solid rear end.. And i plan on stroking the 351w in the near future..
  4. yellow75
    Tillamook Oregon
    I would cut it down, probably cheaper in the long run, trying to stuff the wheel with enough backspace into the fenderwell would be difficult and the longer axles will be more prone to twisting.
    If you could stuff some wheels in there they would have to have around 6" backspace
  5. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Yep ! I'd agree with Maverick Mike .. Get the 9" incher and Cut it to Fit YOUR car . With a stroked 351 you're
    going to need a 9" incher for sure. We stroked two cars , one a 427 and one a 408 and they definitely merit a
    9" inch rear end. An 8" incher wouldn't stay together long. Also if you can avoid the other aspects like fender rolling,
    wheel backspacers , etc. It would save you a lot of time .There are lots of 9" inchers out there .. and there are people that will make it ' fit ' for your car without a lot of time wasted. I wish you success in whichever direction you go .
    Cometized
    (Chip)
  6. primodemo916
    primodemo916 Member
    Sacramento Ca
    Shops in or near sacramento just arnt reasonble every place i called wants $500+ to cut and reweld.. Id do it myself if i had the jig..That doesnt include shortening the axles.. I found an 8 inch rim with a 5.5 offset im going to bolt it up and see what kind of issues i run into.. Summit has a few options..
  7. dyent
    dyent Member
    vancouver bc
    Another option, call Brydon http://www.ebay.com/itm/9-Inch-Ford...m568817931a:m:mkUhyaa6y0_XkgcaeXJ0brA&vxp=mtr, several members, along with myself have purchased from him. Also offers better axles if you decide to up your 351W in the future....
    David
  8. bmcdaniel
    I have a 70 Mustang 9" in mine, was 2" wider on each side. I had my wheels widened 2" to the inside, were 15X6, now they're 15X8.
    www.weldcraftwheels.com
    At that time it only cost $100/wheel and $30-couple dollars shipping.
  9. primodemo916
    primodemo916 Member
    Sacramento Ca
    Thank you i have it bolted up just waiting on my rims..
  10. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    I have no idea if this would work but late model Mustang wheels have all the offset to the outside. I wonder how close it be to working. I have a 9" Versailles rear in mine which is a little wider than a stock 8" and I'm using spacers to use 07 Mustang wheels. Just food for thought.
  11. racing ranger
    racing ranger Member
    Iowa
    72 Comet GT Boss Powered, 83 Ranger S/G, 94 F250 Styleside 4x4, 2007 Ford Focus SES
    71-77 maverick/comet housing is 57" flange to flange. 71 mustang is 60" 65 mustang is 57 1/4"
    New housing ready to bolt in $295 www.quickperformance.com
    Static likes this.
  12. greasemonkey
    Sedalia,MO
    So, it's very possible to run late model wheels. It's been so long since I put thesee on my car but I think my spacers are 1.5".
  13. racing ranger
    Iowa
    If that's the case they should work with out the spacers on a 60" rear end
  14. primodemo916
    primodemo916 Member
    Sacramento Ca
    Ok the rearend is in and im using 68 mustang steel wheels 14x7 with a 4inch backspace.. Sits nice I dont see why it wouldnt work.. I cant find any wider rims with 5.5 or 6 inch backspace..Should i use a spacer for the front wheels to get them closer to the width of the rear end?
    https://m.summitracing.com/parts/vsw-55-5704
    These are the rims i purchased i like the rally look
  15. bmcdaniel
    I wouldn't add spacers anywhere unless absolutely needed. In fact, here in PA it's illegal to have a wheel spacer thicker than 1/4".
