73 4 door project
Discussion in 'Maverick/Comet Projects' started by MaverickDan, Mar 31, 2012.
  1. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Thanks, those subarus can be pretty nasty too.
    Yeah Ive looked at it and have stolen a couple ideas. I have thought about relocating the battery to the trunk and running through the battery area. It's a magnum performance T70 w/ .68 turbine housing, its basically a master power with a polished compressor housing
  2. Joe Dirt
    the t70 should work good, i just put on on a stock aod mustang a 70/68
    spools good and makes great power
  3. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Target is 450whp. Also need to rear gear to a higher ratio maybe like a 3.25 from my 3.80.
  4. Joe Dirt
    450 will be easy at lower boost levels , but you may have to do a injector swap in your powerjection.
    we maxed out 8 50 lbr's on the stang at 14 psi
  5. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    I'm hoping ill get there on 10 psi
  6. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Got the wastegate on today
  7. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Started working on the down pipe today, gettin it curve around the water pump pulley was pretty tricky but i like how its come out so far.
  8. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Not much done lately wrapped the headers and crossover, made the oil feed line, and removed the oil pan to weld in the return bung. Please ignore the sketchy fuel line thats going to be fixed this weekend
  9. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Welded the the return bung in, made the return line today, also repainted and install oil pan.
  10. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Half way there
  11. super sonic mav
    super sonic mav Member
    Zimmerman,Mn.
    1976 Maverick Stallion
    Very,very cool......:thumbs2:
  12. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Thanks, hoping my intercooler comes in tomorrow so I can get started on th cold side.
  13. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Got the intercooler mounted today, started thinking about the piping and can only come up with one solution. Cut a hole in the inner fender well use a U bend down to the intercooler.
  14. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Finished the turbo to intercooler piping today.
  15. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    & this is why i want to get rid of my power steering....looks good.
