Can anyone help me with the correct (regulator, battery, soleniod, alternator) wiring setup for a 72 Comet. I am looking to see if I have this right and if someone could fill in any gaps. I've got no existing wiring aside from 4 wires coming out beneth my battery tray (yellow, Red with blue stripe, Red with green stripe, Green with red stripe); the regulator wiring clip is missing, but I have one coming in the mail. Regulator I: A: to 12V post on soleniod S: to Stator (STA) terminal on Alternator F: to Field (FLD) terminal on Alternator Alternator STA: to S connection on regulator BAT: to 12V connectoin on soleniod FLD: to F connection on regulator GRD: where should this ground connection come from??? unlabeled: is this an additional ground, it's unlabled on the back of the alternator? Soleniod: 12V post: - post: I: S: Battery: +: to 12v connection on selenoid -: grounded to body??? Starter: ...
see if this doesnt help you out some http://www.maverickcomet.com/Wiring/MavWiring/1972/1972MavMain.pdf
condenser question One last thing.... There is a condenser below the regulator, any idea where this should connect to. I didn't see it in wiriing diagram. Thanks
