460 into mav
Discussion in 'Technical' started by AUSSIEBJ, Feb 22, 2006.
  1. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I am very impressed, nice job.
    Dan
  2. wessel
    wessel New Member
    Denison, IA
    1972 Maverick with a 250ci engine (doesnt run at the moment) also a Comet that is supposed to be used for parts
    What are you going to do with the engine that you have taken out of the car? I am looking for an engine for my 72 maverick to use against all the little imports around town. I have a comet that has a 302 in it but I do not really have the time to rebuild it ground up.
  3. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Coming along! (y)
  4. AUSSIEBJ
    AUSSIEBJ http://mmb.maverick.to/at
    NEW YORK
    70 Mav old race car project,70 mav 460 ,C6 9" posi 4.11rear SOLD
    yesterday i dissassembled the stearing column and modified it to accept the new universal joint, what a nightmare that was with out a break down of how it was done, but i got it back together and painted..before i reinstall it i will move the master over ..more pice to come..
  5. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    looking good.
  6. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    How is a M2 conversion going to hold up with a BBF mounted right to the crossmember?
    It seems like an engine plate running over to the subframe might be stronger.
    My experience is that even a stock 460 can break a lot of parts quickly.
    Even if they are not 'souped' up, they have amazing strength (torque) to wreck stuff.
    Just a thought.
    I really don't know...
    Dave
  7. AUSSIEBJ
    NEW YORK
    Amaizingly enough the mustang II cross member is very strong it is about 3/16 thick where as the stock frame rails are about 16 gauge if there is no deteriation of the inner structure, i would think that the crossmember would take more abuse then the stock frame rails ,any way i will soon find out.......Today i removed the master and i am in the process of moving it 3 inches over so i can run a 6 inch booster as well......
  8. Jamie Miles
    Alto, GA
    I've had a few
    Man, that is absolutely awesome!!! My '74 is going to get a MII front end when I get the frame rails straightened. Doubt it'll be a big block going in there though. Probably a Duratec V6 out of a Lincoln. 232 horse power stock, great gas mileage, and lighter then a straight 6 which means good handleing.
  9. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Awesome!!!!! Nice to see a big block going in for a change of pace!!!!!
  10. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    1971 maverick 2dr m2 front end coil over ladder bar rear suspension 472 ci. C-6 tranny
    I finally got my master cylinder moved but no booster on mine.
  11. AUSSIEBJ
    NEW YORK
    Removed the master pic and modified column pic...i think i am going to go with a hot rod 6 inch power booster and master set up so i will have power brakes..i also removed all the wiring from the engine bay and relocated it so as to have a nice clean bay when done...
  12. Cleaver
    Cleaver Member
    MD
    Chel
    Looks like things are going well. Great job! :tiphat:
    I used a master cylinder off a 95(?) Mustang.. Had to drill and tap to make the lines come out the fender side. Still can't use my tall Motorsport valve covers. :slap: Looks like Robert got his to work. :bananaman
    Cleaver
  13. AUSSIEBJ
    NEW YORK
    Havent worked on the mav i have been deciding which way to go with the headers and as you all probably know you cant buy pre made headers so i bought two sets and i will custom make a set i am going with 2 inch dia tubes will be tight but we will see pics on the way........
  14. AUSSIEBJ
    NEW YORK
    well started the headers on the pass side first let me tell you when you make headers make sure you can get them out of the engine bay ...HA HA on me, but they are comming along..Had to go with fenderwell headers as they are 2 inch primarys and they take up alot of room ..........If any one wants more pics of the headers just email me ill send them off to you...Barry scoopbj@aol.com
  15. maverick75
    Looks better and better
    got to use my uncles truck with a 460 EFI yesterday and that thing hauls a$$ even with 900 lbs of passenger plus equiptment...didnt even put it in overdrive:eek:
    now you put that engine in a light weight mav:drive:
