351c in my 72
Discussion in 'Technical' started by Yellow72Mavrick, Nov 9, 2005.
  1. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    Don't kill a Cleveland by keeping the stock manifolds. Period. It has to breathe.
  2. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    i'M CHECKIN INTO HEADERS NOW.
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    We had the same trouble with the manifolds 'grabbing' the towers and binding.
    When it comes to clutch linkage, I tried to use manifolds in mine, and they fit. However, I fit and tested everything before trying to put the head pipes on the manifolds. The head pipes absolutely would not go in and allow the linkage to function. Hydraulic clutch would be the answer IMO.
    I ended up using Tubular Automotive headers.
    Big tubes, at least the 4v set I used. They are kinda like spaghetti though. 8 separate tubes that bolt up one at a time (makes install easy), and 2 pipes criss-cross below engine. Then the collectors slip on with retainer bolts.
    They did NOT work with my steel bellhousing. I had to trim it.
    Tubular makes 2v sets as well, don't know the tube size.
    Also: My swap would have been better on a couple points. Things I would do today if I did the swap again...
    Shaved towers
    No Moroso valve covers (Something closer to Boss 351 covers.)
    Aluminum intake
    More radical innards
    Some things that worked very well:
    Moroso deep pan
    Stock 302 Duraspark box combined with a 400m distributor
    Fan, spacer, and shroud lined up perfect as with 302, but I would go electric fan if I did it again.
    Clutch linkage
    Throttle cable and bracket
    Dave
  4. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    Finaly got some pics to go.
    here are some of my shock tower mods... complete with my crappy looking welds.
    How did your headers work with motor mounts? did you have to change mounts or did the stock one's work?
  5. cyclonewill
    cyclonewill Member
    One other thing: what kinda springs work best under the cleveland? I pulled the springs out of my 4dr parts car and replaced them with the 2dr's springs... and it was so low I had a hard time getting the jack out from under it. Will the 4dr 200 springs work ok under the 2 dr with 351c?
    Also: should i swap the leaf's also?
  6. Yellow72Mavrick
    Memphis, Tenn.
    Well I sent the 351c block to the shop for prep, a .030 overbore, new cam bearings and freeze plugs. I did some horse trading for a set of 70 model 4 barrel closed chamber quinch heads to replace the 72 open chamber heads. Goin with 9 to 1 flat tops. It has a offy 360 degree dual plane intake on it now with a 750 dual line holley. Lookin for another intake that might be better. Thought about a gear drive for timing but may just go with a double row chain and gears.Cam selection is still up in the air right now. I want it to be very streetable since its a daily driver but a little lope couldn't hurt, lol....
  7. ratio411
    ratio411 Member
    Pensacola
  8. Aussie John
    Aussie John Member
    Melbourne Australia
    Nun Yet
    This thread has answered so many questions. Can some one let me know if Tubular Automotive header have a web site as they would be spot on for my 387 Cleverland swap. Dave when you come over i will see if i can get you a ride in a couple of GT from over here, as well as some other stuff. Aussie John.
  9. ShadowMaster
    The ShadowLands
    1969 1/2 Maverick
    Edelbrock Torker intake. Period. Nothing better for street/strip. Stick with the chain for the timing. Camshaft: Call Crane cams and have them grind this for you:
    Hydraulic lifter camshaft
    Intake lift: .524"
    Exhaust lift: .554" lift
    Intake duration @ .050": 224
    Exhaust duration @ .050" lift: 232
    108 degree lobe sep. angle
    It's a great street/strip grind. I've used it for ages and have never been disappointed. If Crane gives you any hassles then let me know and I'll have it ground for you.
  10. ratio411
    ratio411 Member
    Pensacola
    I dunno about that.
    Pete Jackson makes a real purty noise in there.
    I can't bring myself to install a radio when I run a gear drive. :drive:
    Dave
  11. ShadowMaster
    The ShadowLands
    1969 1/2 Maverick
    If you want it to whine.....get a blower. ;) Seriously, the chain will stretch at high rpm and retard the cam timing (slightly) so you will get a bit more upper rpm power.
