351 Windsor Build
Discussion in 'General Maverick/Comet' started by 1973Maverick357, Aug 21, 2009.
  1. Craig Selvey
    I had a 1985 Ford truck with a factory 351 4V engine in it. It featured a Holley built Ford carb.
  2. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Well when I`m wrong ...I admit it. There WAS indeed a 4 barrel 351w made for trucks and vans in the mid. eighties.
    This shows my age.... some of the information on the Hard drive between my ears was uploaded SO LONG ago that it has become obsolete! (late 70`s-early 80`s)
  3. 1973Maverick357
    Cookeville TN
    Thats probably around the year of this truck with same engine how did it run?
  4. maverickoutlaw
    maverickoutlaw Member
    St Marks, Fl
    1973 maverick
    M.A.V
    You are partially right about the 351. What you should have said was that they only made a HI PERFORMANCE 351 was 69.
    In 69 they made 6000 325 hp windsors. Then they started producing the 351 clevland motors and stopped the production of the hp windsor.
  5. GrabA72Mav
    GrabA72Mav Living Our 2nd Childhood
    Eastern Iowa
    72 Maverick (Sold) 76 Aspen R/T Super Pack
    My brother has one of the 69 325hp 351's in his unibody ford truck. It runs "NICE"!! Good Luck on you Winsor build!!!
  6. Craig Selvey
    Ran O.K. Started......got me from point A to point B, etc.
  7. Demmitt
    Demmitt nutz and boltz
    Sandsprings, Oklahoma,
    1976 2 door, 1969.5 2 DOOR
    a set of trick flow heads and a intake and carb . id look around on ebay cl or racejunk.
  8. 1973Maverick357
    Cookeville TN
    I just got the engine the factory breather says "5.8 Liter 4V H.O" Its out of an 85.
  9. mean_maverick
    that engine was available from '84-'86, all of which would be the same thing unless the carb has an '85 tag on it. that would be the biggest determining factor
  10. 1973Maverick357
    Cookeville TN
    Are they any good? The guy is gonna start supplying me with ford motors.... Also there is no transmission what came behind these motors??
  11. 1973Maverick357
    Cookeville TN
