351 headers
Discussion in 'Drag Racing' started by Rocket!, Feb 9, 2011.
  1. mavman
    mavman Member
    Arkansas
    You'll have to have them made most likely.
    The 6208's will work but have to be cut up. Might as well start from scratch and build them the way YOU want since you're going to have to cut 'em up anyway.
    Most of us do front end mods (M2, etc) to make the 351w fit correctly. It's just too tight between the towers for the 351w to fit with headers..or manifolds for that matter. At the very least the towers have to be "notched"
    Lastly---this subject has been covered a million times. A click on the search button would have found it.
  2. olerodder
    olerodder Member
    NorCal
    Just got my headers modified by SPD, www.spdexhaust.com
    and they look great. The merge/megaphone are 321 SS, so next time I will have the rest of the headers redone in SS. Should bring my 60' times down a little................we will see.
  3. mavman
    mavman Member
    Arkansas
    Cleveland heads? Just guessing by the diagonal bolt holes.
  4. olerodder
    olerodder Member
    NorCal
    When the car ran B/SM it did have Cleveland heads, now with the 408 it has set of Roush/Yates Trick Flow mod'd R heads.
    It has some very strangely shaped exhaust ports, but the intake ports are almost the same size as Clevelands.
    We will see how the headers work????
  5. anytakers
    anytakers Member
    Wytheville VA
    1972 maverick grabber
    any pics of the Roush/Yates Trick Flow mod'd R heads?
  6. olerodder
    olerodder Member
    NorCal
    Here are a couple of pictures.
    You really can't see the exhaust port too well, but is flat on the bottom with a scallop on either side.
    When I get the heads back cleaned you will be able to see the shape better.
  7. 0nealprince
    0nealprince Member
    north alabama
    1972 comet
    how well did the headers fit?
  8. 0nealprince
    0nealprince Member
    north alabama
    1972 comet
    how well did the headers fit? thanks Oneal
  9. 71gold
    this thread is over a year old, you may have to give them more than a min. to respond...:huh:
  10. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    Haven't got the engine in the car yet. Sorry but had some bad times and haven't been able to work on the car. I will be getting my second knee brace here in about 2 weeks. Then I will have both knees stable and maybe I will be able to get back at it. When I do I will get the pics of the install posted up for all to see.
  11. 0nealprince
    0nealprince Member
    north alabama
    1972 comet
    computer shut down, i did not know the 1st post was completed,will try to do better next time. if you have any info on 351 headers please let me know, I have Joe Dirt's old car with a 351 in it, it still has the AJE cross mount and rack and pinion steering. Thanks Oneal
  12. 0nealprince
    0nealprince Member
    north alabama
    1972 comet
    Do you have a picture of the starter side with the header? Thanks Oneal
  13. valleyracer
    valleyracer Member
    Ottawa Canada
    1977 Maverick Drag car 399 engine,C4 trans,9"with 4.33 gear ET 10.25 @ 128 mph
    Making the 6901s fit with the 399 stroker!
      File size:
      184.5 KB
      File size:
      163.5 KB
      82
      File size:
      160.2 KB
      86
  14. valleyracer
    valleyracer Member
    Ottawa Canada
    make 6901s work in progress!
    A few pics taken today...lot of changes
      File size:
      172.5 KB
      56
      File size:
      167.3 KB
      53
      File size:
      175.7 KB
      49
      File size:
      187.3 KB
      49
      File size:
      164.3 KB
      71
  15. 0nealprince
    0nealprince Member
    north alabama
    1972 comet
    If you don't mind, what head are you using? Thanks Oneal.
