302 harmonic balancer on a 289
Discussion in 'Technical' started by maverick7072, Mar 15, 2016.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    I have a 67 289 with A BAD HARMONIC BALANCER ! does nayone know if a 302 balancer will work my 289 has a 3 bolt pattern and I think most 302,s have 4 bolt holes but if a 302 balancer will work I can change pulleys as well,just need help from anyone who is more up on this info thanks
  2. mojo
    You can have the balancer rebuilt and not have to worry bout modifiying anything.
  3. dyent
    dyent Member
    vancouver bc
    302 balancer will work, so long as it is same 28 oz., imbalanced as your 289, but like you mention, will have to change over to 4 bolt crank pulley. Earlier 302 balancers from 68-70 used 3 bolt pulleys. Or you can rebuild or probably the easiest, why not buy a new 289 balancer? Then you don't have to worry about using some 40 year old balancer, which may have "issues" too.........
    David
  4. bmcdaniel
    You can drill some holes in the 3-bolt pulley and put it on the 4-bolt damper. The pulley is located by a raised lip in the center of the damper, you can't put it on off-center. One of the bolt holes will align, put a bolt in it and drill holes for the three other bolts.
    Or get an aftermarket damper that comes with bolt holes for 3- and 4-bolt pulleys. That's what I'm running.
  5. mav man
    mav man Member
    wi
    70mav
    I have a new balancer with the 3 bolt pattern if you're interested send me a message.
  6. rthomas771
    If it was me I'd get the correct balancer. You might run into belt alignment problem and timing mark location.
  7. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    There's several new 3 bolt balancers on ebay.
