3 Speed Tail Housing
Discussion in 'Transmissions' started by Ford Guy, Feb 22, 2009.
  1. Ford Guy
    Ford Guy Member
    Pinnacle, NC
    1973 Grabber
    I have recently acquired a 3 speed toploader that I am assuming came from a truck because of the very short tailhousing. It is only about 7" in length. What is involved in swapping the tailhousing, and will one from a 4 speed toploader work?
  2. PaulS
    Since the output shaft is the last thing that comes out of the case you might as well rebuild the three speed.
    A four speed toploader output shaft will NOT work in your transmission.
  3. Ford Guy
    Ford Guy Member
    Pinnacle, NC
    1973 Grabber
    Ok, thanks for the info. Now another question. As long as the shifter comes up in a good position, this tranny will still bolt right in with the exception of needing a onger driveshaft, correct? I have the bellhousing, clutch, and a 164t flywheel with it that was bolted to a 351W.
  4. Ford Guy
    Ford Guy Member
    Pinnacle, NC
    1973 Grabber
    This is what it looks like.
  5. PaulS
    As long as you can get a driveline made it should work fine.
    Talk to the driveline shop about the length and find out what the "critical speed of your shaft is - that way it will last longer and give good service.
  6. Ford Guy
    Ford Guy Member
    Pinnacle, NC
    1973 Grabber
    Thank you, I know I am probably bothering you with these stupid questions, but I appreciate your help. Thanks again.
  7. PaulS
    It is never a bother educating others.
    The guys that I learned from gave me knowledge and I pass it on with the things I have picked up along the way.
  8. bartikus
    bartikus Member
    salt lake city, ut
    wow that thing does have a short tail shaft do you know what it came out of.
  9. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Think the original questions were answered so don't think its a highjack to ask a related question. Never heard of critical speed for a drive shaft. What's that?
  10. PaulS
    There is a speed (rpm) at which any driveline becomes unbalanced. It is determined by the length, diameter and wall thickness. I don't have the formula at hand but I do know that shortening a driveline is always safer than lengthening one.
