250 upgrade
Discussion in 'Technical' started by two_tone_greene, Dec 6, 2006.
  1. two_tone_greene
    two_tone_greene New Member
    Maverick
    Was wondering if anyone could help me out, I had been looking to keep my 72 Maverick with a 200 in it. So far have found more 250 engines rather and was wondering what all would need to be changed if I wanted to swap out my 200 for a 250? I have a 3 speed manual transmission in my car and want to keep the car with a manual transmission. So I am guessing the 250 had a different transmission and bellhousing, also how about the driveshaft slip yoke? If anyone knows what all I would need the help would be appreaciated. I am thinking they probably had 3 speed transmissions with the 250 and am wondeirng which transmission this would be also. Any help would be welcome on this.
  2. mleega1
    mleega1 MAVERICK MARK
    Lagrange, GA
    1971 Maverick 2015 F150 2003 Explorer
    The trans will work, you will have to have a small block bell housing, and a flywheel from a 250 as they are 0 ballance. I think one from a 300 six will work but im not 100% shure. The slip yoke will not need to be changed, and I would think the Z bar would have to be changed as well, not shure. I would go with the bigger six myself if my 200 wasnt in such good cond with only 39,000 miles on it. I know that doesnt anwser all of your questions but its a start. I have a 302 bell housing if you need it. Ill sell it cheap as I have no need for it. Good luck with your car! Mark
  3. PaulS
    Switching to a 250 is not hard at all. Remove the tranny and engine w/ bell housing.
    Install the 250 with the clutch and bell housing. Bolt the tranny that you have to the new bell housing. I don't know if the "Z" bar is different or not - try your old one to see if it will fit. I seem to remember that the adjusting screw is different, but I think thr rest will be fine. It has been a long time since I did thatswap, so cut my old memory a little slack.
    You will want a larger radiator but I don't think there is a problem with matching hoses or sides. Easy swaps like this don't happen very often.
