2000 miles on fresh rebuild...tapping?!?!?!?!
Discussion in 'Technical' started by random hero, Aug 15, 2009.
  1. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    there is an intermittent tapping sound, and it's getting worse. it used to just happen in park and go away when put into drive or reverse, now it does it all the time and goes away when there is a load on the motor (alight acceleration) but it comes and goes frequently...what could it be(i know it's not a lifter). loose rocker arm shaft? rod knock, bad bearing? any ideas...it's getting worse by the day. any help at all would be great (y)
  2. maverick maniac
    maverick maniac Banned
    owensboro ky
    fuel pumps some times do that
  3. Mavman72
    Exhaust leak...
  4. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    Why do you say it is not a lifter? I remember hearing about a lot of bad lifters a year or two ago. It was said a lot of them came from China then.
    I also agree that an exhaust leak will sound a lot like a bad lifter.
    Take a piece of fuel hose to your ear and run the other end around the headers at heads. If you get near a leak you will hear it.
    clint
  5. yellow75
    Tillamook Oregon
    x2 they sound a lot like a lifter
  6. baddad457
    Cam wiping one or more lobes.
  7. lastchance
    lastchance Member
    Hingham , Massachusetts
    When you say it goes away with a load on the engine I`m thinking torque converter bolts are not tight.
  8. Joe Dirt
    loose torque converter nuts / rocker arm
  9. justin has a 74
    kentucky
    x3:tiphat: i have a big exhast leak
  10. random hero
    hudson valley
    1972 maverick
    i know it's not a lifter b/c i know what a lifter tap sounds like, and i know it's not an exhaust leak b/c it's a 200 I6 and the sounds is internal...but it may be the torque conterter bolts...i also thought it was the rocker arms aswell..but now atleast i have a place to start...btw my fuel pump is the original and has over 100,000 miles on it so it may very well be that also. but it goes away with a load so thats leans me toward torque converter bolts...that being the cheapest and easiest (i work in a shop so i have a lift) i'll check that first. thanks for all the help guys :thumbs2:
  11. lastchance
    lastchance Member
    Did you repair the noise? What was it?
  12. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Cracked flexplate?
