200 6cyl to v8 what do I need?
Discussion in 'Technical' started by ColumbiaJoe, Sep 13, 2014.
  1. ColumbiaJoe
    ColumbiaJoe Member
    Connecticut
    1976 maverick
    Hi I have a 1976 Maverick with a 200 inline 6 cylinder. I want to put a 302 v8 in. What parts on the car IE mounts ect. have to be changed? The car is a 3 speed automatic and the transmission will be up graded too.
    Thanks in advance for any info.
  2. 71gold
    the 200 bellhousing needs to be changed to one from a 250/302 for one thing.
  3. Krazy Comet
    Dismal Swamp
    You'll need to plan exhaust mods whether you go dual or single, also need motor and chassis mounts, all the pulleys/brackets, wiring harness for v8(assuming they are not with engine)... If engine is late model 5.0 roller cam, toss in a oil pan, pickup, and steel geared dist... Additionally things like throttle linkage, a V8 radiator, correct flexplate/flywheel for your upgraded transmission in addition to torque converter, bell housing etc etc...
    There are several good threads listing needs, good luck on finding them though...
  4. ColumbiaJoe
    ColumbiaJoe Member
    Connecticut
    1976 maverick
    I see your point about good luck finding the threads. Seems the only threads I can find are threads referencing good threads. If anyone has a link to one or several it would be appreciated. what I really need to know is what chassis parts will I need. And possibly where to get them,
