2 bbl to 4 bbl adapter issues
Discussion in 'Technical' started by wolfheads, Oct 11, 2015.
  1. wolfheads
    wolfheads MadMav
    Florida
    73 Maverick / 2000 Harley Low Rider
    Does anyone know if they make an adapter to install my Motorcraft 2 bbl carb to a 4 bbl intake? I bought a Mr. Gasket adapter but the base for the Motorcraft 2 bbl is not large enough. It will leak air/fuel. The 2 bbl I have has a slightly larger base.
    Thanks
  2. schroensr
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    I have always changed the intake and carb at the same time. Never used a 4 barrels intake to a 2.
  3. Krazy Comet
    I'm lost here, a 2bbl Autolite/Motorcraft/Holley share the largest base pattern there is...
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I am guessing he's talking about the adapter being too small for the carb. I have seen this when I was in auto parts (23+ years ago), some carbs have passages that extend beyond the adapter creating an issue.
  5. wolfheads
    wolfheads MadMav
    Florida
    That's exactly what I'm talking about. The Motorcraft 2 bbl overlaps the adapter in the front by a good 1/4".
  6. RMiller
    Kennewick, WA
  7. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    what you need to use is a flat plate under the carb to seal the gap!
    Edelbrock used to sell a flat steal plate to do the job, the Idea of a 2 barrel on a 4 barrel manifolds was so the guys that were restricted to using a 2 barrel carb to confirm with class rules can use the latest in intake designs!
  8. Run Free1_70
    Run Free1_70 Member
    Helena, Montana
    1970 Maverick Grabber 200/six, swapped to 306ci
    I actually have a motorcraft 2 barrel on my parts list, complete with adapter that came of a performer 289 manifold.
    The motor was built by a drag racer, came with the 2 barrel and adapter....also had a shutoff for heater hose.
  9. mav1970
  10. wolfheads
    wolfheads MadMav
    Florida
