1973 4 Door window regulator replacement!
Discussion in 'Technical' started by 72Cometsedan, Aug 4, 2025.
  1. 72Cometsedan
    72Cometsedan Member
    Georgia
    1972 Comet 4 door sedan 302 1973 Maverick 4 door sedan 200
    Can anyone confirm that a 2 Door window regulator will "NOT" work in a 4 door! I am guessing not, but thought I would submit this. 2 Door regulators are easily found on the web, not so much with 4 Door regulators.
    The door glass is loose in the door, having come loose from the regulator. The glass is not fully in it's track as seen in the photo. I have not yet removed the door trim panel to see exactly what's going on in there.
    Thanks for any help offered !!
  2. 72Cometsedan
    72Cometsedan Member
    Georgia
    Anybody got a 4-door window regulator for sale in their stash?? Prefer NOS. Thanks!
  3. 71Mavrk
    71Mavrk Member
    Nevada
    Is the mechanism bad or just the rollers which have worn out. I'm just guessing that if it is the rollers they would use the same parts as the two door. I seem to recall buying the rollers years ago when I rebuilt mine.
    Micah
  4. 72Cometsedan
    72Cometsedan Member
    Georgia
    Micah, thanks for your comment. I believe that only the rollers are bad. I think those are available on AutoKrafters.com. I still need to remove the trim panel and look inside.
  5. Craig Selvey
    2-door and 4-door regulators are different.
    Before you start buying parts, you need to determine what the issue is. I am going to say your regulators are just fine. I have never seen them wear out. My guess is that the plastic rivits holding in the glass have came loose, are missing, broke, etc.
    Start by removing the door panel and ascertain what this issue is.
  6. 72Cometsedan
    72Cometsedan Member
    Georgia
    Craig, you are correct, thank you. Do you have the plastic rivets holding the glass in place for sale, or know of a source?? Thanks!
  7. Craig Selvey
    I believe Melvin's Classic Ford Parts now has them back in stock.
  8. 72Cometsedan
    72Cometsedan Member
    Georgia
    Yes they do! I just placed an order for plastic rivets as well as rollers.
    BTW I love your Maverick Heaven pages on your website !!
    Craig Selvey likes this.
