1972 maverick transmission question
Discussion in 'General Maverick/Comet' started by Jcast98, Jul 13, 2020.
  1. Jcast98
    Jcast98 Member
    West coast
    1972 ford maverick
    I have a 72 maverick and my transmission went bad. I took out the transmission but forgot to take pictures as I went to remember the process. Does anyone have any pictures of the transmission mounted or anything that would help me?
  2. 71gold
  3. Jcast98
    Jcast98 Member
    West coast
    1972 ford maverick
    Thank you!
  4. ike72com
    ike72com Member
    Charleston SC
    Important thing to remember is to install convertor fully. When bolting up make sure trans and engine is fully seated without binding. Flywheel convertor hole/bolt lined up. Everything else can be figured out. Or ask a specific question.
    71gold and Krazy Comet like this.
  5. 71gold
    agree...
    "Important thing to remember is to install converter fully."
    don't pull transmission up with the bolts. it should slide on by hand if the converter is seated all the way.
    don't ask me how I know...:slap:
    if rebuilt ask the builder what fluid type to use...:yup:
  6. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I don't have to ask!:beerchug:
    71gold likes this.
  7. Jcast98
    Jcast98 Member
    West coast
    1972 ford maverick
    Why do you think. Should I buy a transmission of someone or get mine rebuilt?
  8. ike72com
    ike72com Member
    Charleston SC
    Been there done that. Never trust another man used trans unless you trust and know that man!
    If your current trans just started slipping, rebuild is the way i,ll go.
    71gold and mojo like this.
  9. Jcast98
    Jcast98 Member
    West coast
    1972 ford maverick
    Thanks for your knowledge. Just sent my tranny to get rebuilt should be ready in 3 days or so then I’ll go from then.
    71gold and ike72com like this.
  10. 71gold
    be sure to get a new converter to go with the new rebuild...:yup:
    I suggest one a little higher than stock.
    ike72com likes this.
  11. Jcast98
    Jcast98 Member
    West coast
    1972 ford maverick
    They are also checking the converter but what converter would you recommend?
  12. 71gold
    how many miles on the converter that's in it now? most shops want warranty a rebuild without a new converter. the old one will have metal and clutch dust in it. from my understanding without cutting the converter open there is no way to clean this out.
    I would suggest calling a converter company and they will ask you a few questions. Edge converters is my choice.
    HP of engine
    torque of engine
    rear gear ratio
    weight of car
    street or strip car
    may be more...
  13. ike72com
    ike72com Member
    Charleston SC
    Frank is right on with convertor info.
    I have an edge in mustang and love the 3500 stall.
    For your car and cam If you,re planning on burning any rubber then a higher stall around 2500 is the way to go!
    If you need explanation on how the higher stall e/a ffect performance just ask.
  14. Jcast98
    Jcast98 Member
    West coast
    1972 ford maverick
    This is what my question was. I don’t know how this goes connected so can anyone help me out?
  15. Jcast98
    Jcast98 Member
    West coast
    1972 ford maverick
    This is another picture from the same issue.
