1970 Drum Brake Hydraulic Hoses
Discussion in 'Technical' started by Joe Robinson, Aug 11, 2015.
  1. Joe Robinson
    Joe Robinson New Member
    I need to find a substitute for the original brake hoses. No one makes these for drum brakes for the front anymore. There has to be something close enough to use. Has anyone seen an application that works?
  2. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    They are all over E bay
  3. Krazy Comet
    Dismal Swamp
    I believe it was '70 or '71 Stang that wheel cylinders are same and hoses are just slightly longer...
    Another solution is swap to '71 Maverick wheel cylinders and use the matching brake hose...
  4. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    Have you seen the new 2016 Melvins Classic Ford Maverick catalog?... They list a substitute hose for the 70 model.
  5. EstablishMint
    EstablishMint Member
    Mahopac New York
    1970 Ford Maverick, 1972 Ford F250 Camper Special, VW Passat, GMC Sierra
    I know that I'm looking at an old post, but I just looked through the Maverick section of Melvin's online catalog and no substitute hose is mentioned there, that I was able to find. I'd prefer the original lines because I recently replaced shoes, cylinders, and hardware all with original type parts. I'd use the Mustang ones if the only difference is greater length; anyone have a part number for me to cross reference?
  6. Acornridgeman
    Wisconsin
    They are in the Melvins catalog - part # H78073 for the LH and H78074 for the RH - $55 each - these are the Mustang ones. Read the description for what you need to do for the '70 Maverick
    If you have the old hoses and a good hydraulic hose shop in your area - they can rebuild yours for you.
  7. dyent
    dyent Member
    vancouver bc
    you may want to look at this option, I know it is not original OEM that you are looking for but...........
    https://www.ebay.com/itm/FRONT-STAINLESS-BRAKE-HOSES-Ford-Maverick-1974-1975-1976-1977/332248793510?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
    also, these are for Disc brakes, but check out his other listings and you will find ones for drum brakes, far better than original, DOT approved etc..... I have their hoses and Nick can custom fabricate to suit your application.
    David
    apparently, they had a fire in their shop and will not be up and running until the new year........
  8. EstablishMint
    Mahopac New York
    Thank you! I just punched those numbers into the Melvins catalog and they came right up. Hadn't found them looking through the online catalog.
  9. EstablishMint
    Mahopac New York
    Thank you, that would be a good option to look into but hopefully I can order the oem type through Melvins now.
    Ronald Hopkins likes this.
