150 hp to 275 hp
Discussion in 'General Maverick/Comet' started by HOMERMAV, Nov 25, 2008.
  1. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    It may be true for you, but not for everyone. You have ported heads stealth, intake domed pistons, whatever... Your car runs good with a double pumper...... Now I may only be getting about 235-240 horses to the ground(probably a little less because I am running an AOD), but with my vacum secondary carb I have probably as much fun as you do but I am getting 19-21 mpg. instead of your massive 13 mpg.
  2. justin has a 74
    kentucky
    i think the horsepower ratings were full of crap back in the 80's, they may have just lied but i would guess the 302s would make 200
  3. 69GT
    69GT Member
    Fresno
    72 Grabber Maverick.
    Sounds like it's not an H.O. motor to begin with. 150 HP and roller equipped sounds like a LTD or Towncar motor. It probably has cast pistons instead of forged or hyper U like the H.O. Mustang/Mark VII motors.
    I don't see how you can get that power for under 1K without a power adder like nitrous.
    I'd buy used Twisted wedge heads ($1000+) and an F303 ($100 or less used) . Roller rockers ($100+used). Edlebrock Air gap dual plane ($150 or less used).... I could see it for between 1K and 2K Might get close. Check for valve to piston clearance before running.
  4. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    yes the motor came out of a 1989 crown vic and i do plan on another set of heads that have been reworked ported and polished if i can get close to 250 or 275 i will be happy. roller rockers are a must e303 cam, 600cfm carb,headers duel exhaust,mallory ignition maybe differant pistons. depends on the heads and yes maybe a little blue bottle to help it burp a little.
  5. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    With all you're doing maybe just a crate motor would be cheaper.
  6. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    yes but i really want to build the motor myself and i think i will be able to do 250 hp without much effort. some good bolt ons alittle internal work good heads should do it. if that dont work i will just put a nos bottle on it.
  7. Blown 5.0
    MS.
    1974 Maverick
  8. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    sorry blown 5.0 but i think thats a little much for me. awsome but maybe my next project.
    thanks for the input
