Will this work???
Discussion in 'General Maverick/Comet' started by Craig Selvey, Jun 21, 2005.
  1. Craig Selvey
    The 1970 I just bought has no fan belt. Instead....it has this little motor for the water pump/fan. Will this work? I have seen this on drag cars....but never had one before. I just want it to work long enough to get the car running so I can sell the motor. It is not wired up....it has two wires. Just hook up up to some juice and go?
  2. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Should work just fine...we run one like it on my Dad's car at the track. I'm not sure on the wiring though...you may just have to hook the wires up and see which way the water pump turns. If not the right direction, just reverse them and try it again. Should be fine for what you're wanting to do though.
    Later,
  3. Burlap1
    Burlap1 fat lazy truckdriver
    Urbana ny-wine country finger lakes wines are best
    1983 f-150 4wd,1971 cougar parts car,1973 maverick parts car,1970 maverick formerly a gramma's grocery getter,1984 f-250 460 powered,1976 f-350 u-haul,and some chevy's
    :yup:and thats not even southern engineering!!!:biglaugh:
  4. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    1971 maverick 2dr m2 front end coil over ladder bar rear suspension 472 ci. C-6 tranny
    I think I would pull the fan off Craig....might be a little to much....I run one on my car.
  5. Craig Selvey
    It's a clutch fan if that matters.
  6. don graham
    if you pull the fan off you won't have any fan at all. i run one on the race car but i also use an electric fan. you'll be able to start the motor but you won't want to run it too long.:)
  7. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    I ran one just like that for a couple of years, on the street and at the track and it kept things very cool. I just swapped it out for an electric pump......
  8. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    Craig that motor should run either direction so hooking it up backwards shouldn'tresult in frying it. Just need to hook it up and swap the wires if needed
  9. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    thats what I was thinking, but I could not remember for sure.
  10. Craig Selvey
    I got it working this evening. Yes...you can reverse the direction.
    Got the car running again as well........Wooo Hoooo!!!
  11. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    so craig you going to bring it to drag day for roundup ??looks like it would make a fun car to take down the track
  12. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    I am betting yes :D
  13. Craig Selvey
    The car has absolutly NO brakes. Push on the brakes.......fluid shoots out of the front brake line on the firewall near the heater fan motor....and out of the rusty brake lines on the rear axle. All 4 floorboards are gone. Some patch work was done....but still nasty.
    Car had a B & M floor shifter. Cable wasn't hooked up right. instead of missing with it........I cut a hole in the floorboard so I could reach down and put it in gear.
    Here is an interior shot.
  14. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    I thought the Shelby Mavericks came with the hole already 'installed'. :hmmm:
  15. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    If you want to sell that setup let me know
    I already have the motor, but need the pully's and the belt
    But email/pm me and we can talk.
