will these 302 mounts work on my 70?
Discussion in 'Parts Interchange' started by satchelmcqueen, Jul 31, 2015.
  1. satchelmcqueen
    satchelmcqueen Member
    north georgia
    found this in the new melvins catalog.
    will these work in my 70 for a 302 swap? or am i missing something?
  2. mercgt73
    mercgt73 Member
    Yes, but those are just the motor mounts. You will also need the V8 frame stands.
  3. 71gold
    302 or 5.0?
  4. satchelmcqueen
    north georgia
    302 is a 5.0 lol
  5. 71gold
    most refer to a "302" flat tappet..."5.0" roller...
    I was just wondering if it was an old 302 or a later 5.0 roller motor.
  6. Krazy Comet
    First "official" 5.0 were in the '78 Mustang II, seven years before the first roller versions... The '79 Fox Stangs were first with the 5.0 on front fenders...
  7. 71gold
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Yes, which is funny because both displace 4.9 liters, not 5.0. Chevy's 305 is a 5.0.
  9. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    4.9 is not correct ether it would be 4.95 but that is getting a little sticky! 61 x 4.9 is 298.9 ! 61 x 4.95 is 301.9!
  10. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Nope. It's not even 4.95. It's 4.943 . Since it is less than 4.95, you'd round down to 4.9, not up to 5.0.
    Of course boring it 030 or 040 changes that.
  11. Mavit
    Mavit Member
    Prince george bc
    The reason for the 302 being called the 5.0 was back in 1966 when the Trans/AM race series first started the engine size limit was 5.0 liter! that is why both ford and Chevy built there 302 engine with 4 bore and 3 stroke to be as large as possible and still be under the limit! For Trans /Am the boss 302 and Z/28 302 were known as 5 liter engines!
  12. Krazy Comet
    The actual displacement of a Ford 302/5.0 is 301.5936 cu in... OR 4.942234 liters...
    FYI a 300/4.9 I6 is 300.08 cu in, or 4.917430L
    FYI #2 Ford has lied about engine size for years ,the famed 427 is only 425Cu in(424.965)
    The 428 is 427(426.544), of course since the 427 had been around for a few years, they couldn't very well call it a 427...
