will a 351 m fit in my 74 comet
Discussion in 'Technical' started by cometguy410, Apr 19, 2009.
  1. cometguy410
    cometguy410 Member
    maryland
    74 Comet
    today im going to look at 2 motors .the guy has a 302 and a 351m just wondering if the 351m will bolt up to my c4 tranny .will i run into any trouble with the motor mounts .basiclly im looking for you guy opinion on which motor i should get thanks
  2. 71gold
    is a ...5.0 roller...one of the choices...:bouncy:
    ...:yup:...
  3. daydreamer
    daydreamer Mavmenace
    Oshawa, Ontario
    1972 Ford Maverick
    I THINK YOU SHOULD GO THE 302 AS EASE OF INSTALLATION is better than the 351M. I believe the 351M has a different bolt pattern on the bell housing, but maybe not. Also there are more performance parts available for the 302 if you are considering increasing the HP.JMO Ron:)
  4. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    will a 351 clevland fit?
  5. baddad457
    The 351M will DEFINATELY NOT FIT. Even if it would, it's a turd that wouldn't get out of it's own way when you nail the go pedal. The 351C will fit.
  6. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    do you know of anyone here that has a clevland in ther maverick?
  7. JHodges
    JHodges thumper
    Dora Alabama
    I would get the 302. A 351m uses different mounts has a different bell housing pattern and won't fit with the shock towers. A 351m is a smog era truck and heavy car motor
  8. sierra grabber
    sierra grabber Certifiable
    northern nevada
    ratio411 HAD one in his back before aftermarket, he took it back out at some point (probabaly still before aftermarket) it will fit but spark plugs are a pain if you dont shave the towers or make some mods. also a lot of other things he had to do. i would pm him if you are serious about the cleveland.
    BTW back on topic, 302 not the 351m any other 351 i would put in.
  9. starsky74
    starsky74 Technician
    Hackberry Louisiana
    351m is a piece of trash. only thing its good for is adding weight to a car headed for the scrap yard. i pick the 302, no matter the year, and jus be lucky if its a roller. in fact the only 351 worth putting in a mav is a windsor.
  10. baddad457
    ;) You're too young to have experienced a Cleveland....................:dance: But I'll let you in on a little secret..........the motors the Nascar guys are running today are basically Windsor blocks topped with Cleveland heads.:thumbs2:
  11. cometguy410
    cometguy410 Member
    maryland
    74 Comet
    its not a roller:mad:
  12. cometguy410
    cometguy410 Member
    maryland
    74 Comet
    thanks for all the input ill go wit the 302.:thumbs2:
  13. starsky74
    Hackberry Louisiana
    no i have, dont worry. im still a "hater";)
