will 255/60 R15 clear with 15x8 3 3/4 back?
Discussion in 'Technical' started by Flamesoldier, Apr 3, 2009.
  1. Flamesoldier
    Flamesoldier Member
    1973 Ford Maverick 302
    I have two 15x8 torq thrust II wheels with 3 3/4 backspacing for the rear of my mav. The tires i have are 255/60 R15. Will this fit anyone run this combo?
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    The BS with an 8" rim should be 4" or better for best fit,
    but that should work. You might have to roll the fender
    seam (lip) up to give some outside clearance.
    IMO 255s look best on 7" rims, but 8s will do the job.
    Do you have the rims in hand to give them a try?
    If not, then I would wait and see if anyone has tried
    that combo. I have test fit 7" with 4" BS and 255s
    and liked it much. However, that rim is more or less
    equal to what you would see on the outside if you
    were to use an 8" rim with 5" BS.
  3. tim keck
    sharps chapel,Tn
    Should work,but like ratio sez,you might have to roll the lip.I had 15x8 w/3 3/4 bs on my Comet w/235/70s.they fit well,but my fender lips had already been rolled.
  4. 1moregear
    1moregear Member
    mississippi
    74 and 76 maverick
    I have two Mavericks one stock and one not so stock. I run 15x8 and 255 60,s on both of them , tires fit real nice inside fenders and no airshocks.
  5. scooper77515
    I have 255/60r15 on mine. 15X8 Cragars, with 4-1/4 BS. I have about 3/8" clearance at the springs, and rub on the fender on hard launches.
    In my opinion, you may have issues with the fender. You would be moving those tires another 1/2" closer to the femders than mine are. I don't think you have the space to move them that far.
  6. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    thats odd scoop, mine don't rub and i have same thing as you almost identical picture too hehe
  7. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    I got the same combo too 8" rim 4 1/4 back space with lots of room.Scoops car must sit lower or something.
  8. scooper77515
    So, you guys aren't hitting the fender?
    Mine only does it when I am at the track and really launch hard. And it has been corrected by putting CalTracs on to limit downward travel.
    That first picture I thought it was mine. Looks almost exactly the same.
    Regardless. this guy is putting another half inch out toward his fender. Do you guys have room for that?
    And yes, I have mine sitting a little lower than stock, by about half an inch. I like the hunched down look all around.
  9. RatRodRivett
    RatRodRivett Member
    Austin TX
    1976 4D Maverick
    Do this same BS work using 8" for the front as well?
