wider?
Discussion in 'Wheels and Tires' started by mavmanerick, Jul 12, 2007.
  1. mavmanerick
    royal city, washington
    so right now i have p195/75r14's on my car and its time for a new set... so im wondering if i can get em any wider than they are now???
  2. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    1970 and 1975 Ford Maverick
  3. RabidCustoms
    245/60-14 fits nice
  4. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    'Depends on what wheels you plan to use....
  5. Thack
    Thack vision advicator
    Moreno Valley Ca
    I'm liking the 275/40-17's myself although they may be a little loose on a 14" rim :D
  6. mavmanerick
    my stock wheels....
  7. bmcdaniel
  8. mavmanerick
    im not getting my wheels widened... i barely have enough money for tires, just wondering how much wider i can get with the stock wheels....
  9. T.L.
    T.L. Banned
    Southern Colorado
    You need to find out if your wheels are 4-1/2" wide or if they are 6-inches. If they are 4-1/2" (my stock wheels were 4-1/2" on my '73), then you already have pretty much the widest tire that you can practically use. You can go as wide as 225/60 on a 6-inch rim (but 215 would look better)...
  10. RabidCustoms
    good point(y)
    I always forget the early cars had narrower rims.
  11. mavmanerick
    hmm this is interesting.... im afraid mine are 4.5" wide... damn that is really skinny...:mad:
  12. CaptainComet
    Wider
    My first Comet, that I had in the 80s, came with 14x4.5 inch rims. I managed to get a pair of 14x7s from a station wagon, and ran 245-60s out back with no problems. 195-70s were on the front and I believe that actually was a bit wider than recommended for such a narrow rim.
    Of course, this will only work if you have 5 bolt axles.
  13. mavmanerick
    how come it'll only work with 5 bolt axles? and did you have any problems while you were running the wider tires?
  14. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    You may have to make a trip to your local junk yard to search for some wider wheels......I believe I saw some in the for sale section on here
  15. mavmanerick
    well i dont wanna buy new wheels then have to buy tires too, so i guess ill just have to get the same size.... anyway, smaller tire=easier burnout:dancing:
