why is my mav do this?
Discussion in 'Technical' started by Mavboy, Jul 6, 2005.
  1. Mavboy
    Mavboy Member
    Calgary Alberta Canada
    1976 2dr 302 Maverick
    why is my mav doing this?
    i have to figure out what is going on and how to stop it. is it just bad shocks? if so what is a good mid range shock for street/strip driveing:49: :confused: :90:
    http://i8.photobucket.com/albums/a40/Mavboy/Rightsideshock.jpg
    thas the right side
    http://i8.photobucket.com/albums/a40/Mavboy/Leftsideshock.jpg
    and the left
    HELP!!!!!!:cry:
    oh and where can i get something to replace the factory tower brace (the light blue thing in the back)
    http://i8.photobucket.com/albums/a40/Mavboy/EngineBay1.jpg
  2. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    It tells me you have front suspension problems, bushings etc...I had same problem with my front shocks...check upper and lower bushings for movement thats what was wrong with mine when they get old and have slack in them its gotta go somewhere...
  3. Mavaholic
    First thing I would suspect would be the shock its self. Recenter the top, unbolt the bottom and spin it 180 degrees and reattach. See if it still walks off towards the front. If the base isnt welded on perfectly straight, it will put side pressuer on the top mount. After that, check your upper A frame bushings as stated above. Lastly it could be the car had a front end collision at some time in its life.
    There are no after market braces available for your car. With the power brake set up, you cant even modify mustang stuff to work.You'll have to make your own. If its just the blue you dont like, take them off, strip, and repaint them.
  4. scooper77515
    New shocks are only $18, and take about 30 mins to swap. If you have any doubt, change them.
  5. Cabinator
    Cabinator Member
    So Cal
    74 Grabber, 70 Maverick
    ive seen a couple with cracked a-arms where the spring perch mounts, which is what the bottom of those shocks mount to, also look at the upper arm shafts they tend to wear out, but when they do, they clunk
