Where do you have your tach mounted?
Discussion in 'Technical' started by ESampson, Mar 26, 2013.
  1. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    Where do you have it at? do you like it there or could there be a better spot?
    i have one of the large 5" or so autometer tach's..i had it over in the middle of my dash the last 2 years and when i was up at the line on the track it was actually blocking me from seeing the tree i had to shift over to see around it...right now i have the new wires ran to the base of the pillar on the drivers side..i was hoping to mount it there if it fits, but if there is a better spot..maybe on top of the steering column? (wheel might be in the way of seeing?) id really like to know where you have yours at or where you would put it..because i don't want to move this again.
    thanks in advance
  2. Tannersg1
    Tannersg1 Member
    Classified
    Mine is mounted on the steering column. I plan on moving it though because it blocks the gas gauge and turn signal flashers.
  3. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    Just measured mine.. It's 5" and has the shift light on it as well.. So it is quite large.
  4. rthomas771
    Why do you need a BIG tach? A smaller tach will work. All you need is a shift light
  5. jmgford
    jmgford Member
    Iowa
    Before installing a factory-appearing tach in my cluster, I had a small Autometer tach with a shift light that mounted with a bracket into the ashtray cavity, which kept it low. You could still open & close the ashtray and I ran the wiring throught the cigar lighter hole with a rubber grommet.
    Before building the cluster, I had thought about mounting the tach down in the tray with a remote mini-shift light in the cigar lighter hole.
  6. 71gold
    tach. top right pod...shift light in the middle of the cluster...
  7. jmgford
    jmgford Member
    Iowa
    Cool, Frank. Is that a rocker switch under the shift light to turn it off?
  8. groberts101
    groberts101 Member
    Minneapolis, MN
    probably his nitrous button for those extra long burnouts. :D
    may I ask where.. and from what.. you got your gauges?
    I'll probably just chop the hell out of my dash and customize it like everything else on the car will eventually become.. but I do like that clean stock look even if it were only to be used for a year or so.
    Thanks, Greg
  9. jmgford
    jmgford Member
    Iowa
    Are you asking me or Frank?
  10. scooper77515
    In the way of my fuel gauge, but Here...
    With that old smaller steering wheel, my hands would sometimes hit the button to control the shift light, but with my new-to-me classic larger sport wheel, no problems!
  11. groberts101
    groberts101 Member
    Minneapolis, MN
    sorry.. I wondered if it would be confused.. but I was asking you about your tach.
  12. jmgford
    jmgford Member
    Iowa
  13. groberts101
    groberts101 Member
    Minneapolis, MN
  14. Moneymaker 1
    Panama City Florida
    My little Tach is on the top of the steering wheel......
  15. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Quick Tip... A lot of guys use larger worm-drive clamps (radiator hose type) to secure a tach to the steering column. If you don't want the clamp being as obvious, simply go get some heat-shrink tubing, cut it to the required length, and slide it over the clamp and heat it. It makes the clamp a lot less noticeable, and comes in several different colors. (y)
