wheels
Discussion in 'Technical' started by stevens, Jul 5, 2011.
  1. stevens
    stevens Member
    has anyone ever milled down the front rotors to fit a set of drum wheels?
  2. blueoval428cj
    blueoval428cj New Member
    Two Rivers, Wi
    1972 Mercury Comet 2dr, 1965 Ford Mustang Fastback, 1983 Ford Mustang GLX Convertible 5.0 5spd
    If you have disc brakes, then you need to use wheels that were designed for disc brakes. Or if you have a clearance problem you could use wheel spacers. Hope this will help you.
  3. stevens
    stevens Member
    yep sure did ty
  4. Craig Selvey
    I presume you are talking about the center hub/center of the wheel fitament.
    Best thing would be to get the correct wheels.
    Next best thing to do would be to mill down the wheel.
    DO NOT mill down a rotor to fit a wheel.
