whats the name of the sensor that controls my brake fluid level
Discussion in 'Technical' started by jaxster010, Oct 25, 2012.
  1. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    i have a 71 maverick and my brake light has came on and its leaking around the sensor on my proportion valve...whats the sensor called..
  2. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    Greetings,... I believe you are referring to the "Brake Pressure Differential Valve Warning Lamp Switch". It is plastic and screws into the brake proportioning valve.
  3. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    yes thats it thanks man would the auto parts store have it
  4. Dave B
    Most Mustang suppliers sell them.
  5. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Just a heads-up, fluid should NOT leak from there. The chamber that the switch screws into is sealed on both ends and should be dry. If fluid is leaking from the switch port, the prop valve needs to be rebuilt or replaced. That would be the reason the brake light is on in the first place, replacing the switch won't fix your problem.
  6. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    i put a screw in place of the switch and its not leaking anymore and brakes feel good:hmmm:
  7. groberts101
    groberts101 Member
    Minneapolis, MN
    Not to argue with such a knowledgable guy.. but I'm thinking that switch is in fact a fluid-type switch.. Not a dry switch.
    How would it even function in that manner?
    Anywho. Switches of that design do leak internally from what I've seen through the years and new one should fix you right up. Even though the screw will work.. it's nice to have a light.
  8. mercgt73
  9. tody
    tody Member
    cologne, germany
  10. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Seriously? :rolleyes: Do you really think a plastic switch housing is designed to hold 2000+ PSI brake pressure? :huh:
  11. groberts101
    groberts101 Member
    Minneapolis, MN
    haha.. mine must be different then. It has a metal threaded body with a plastic top. The few that I've pulled out of other various branded cars had fluid come out of the hole when the switch was removed too. Which required the blleding of brakes afterwards.
    Dunno.. they must have all been broke too? :huh:
    oops.. my bad. This is a much different switch from what I thought it was. I quickly pulled mine and it is full plastic with a dry bore. The OP must have a broken/leaky valve as you said earlier.
    Now me takes me foot out of me mouth. :D
