What size brake line tubing for hydraulic clutch?
Discussion in 'General Maverick/Comet' started by 55crownvic, Nov 17, 2013.
  1. 55crownvic
    55crownvic Member
    colorado springs
    What size tubing are you guys using for the line from the m/c to the slave cyl, on a hydraulic clutch set-up? Is regular brake line tubing(1/8 inch) acceptable?
  2. Bryant
    i used 1/4" steel tube with -4 an tube nuts.
  3. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    I would say 3/16".
  4. YotaRacer
    YotaRacer Member
    Gloucester VA.
    75 Grabber
    Brake line size
    I tried -4 hose and it was a bear to push the pedal. I dropped down to a dash 3 and now its so easy you think there's nothing on the other end. Easy pedal.
  5. 55crownvic
    55crownvic Member
    colorado springs
    I'm gonna try -3 hose and 3/16 tubing.
  6. mavgrab302
    I'm using a 30" braided stainless hose from master to salve... Is there any reason to use a hard line ?
  7. Cruzin Illusion
    1972 Grabber
    You want to keep the amount of braided hose in you brake system to a minimum due to it causing a spongy feel. I have seen a high dollar build on the site that has braid line front to rear. I went to talk to a brake specialist, that is currently on the NHRA hall of fame, and it was an overwhelming don't do it.
    With that said 30" is a long stretch in my opinion. I am sure it will work but I would be afraid of a soft clutch pedal. A larger diameter brake line will also give you a soft feel.
  8. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    I fail to see how line size could affect the pedal effort, as it only transmits the fluid between the pistons that do the actual work...
