what shifter will work on a 3 speed o/d
Discussion in 'General Maverick/Comet' started by supermav, May 24, 2011.
  1. supermav
    supermav Member
    clarkston wa.
    71 grabber,65 galaxie drag car,66 fairlane 2 door hardtop,64 falcon ranchero
    my boss is giving me a 3 speed overdrive from a monarch but it has no shifter. do they use the same one as a toploader 4 speed? this one is for my 66 fairlane. the next on will be for the mav.
  2. PaulS
    YOu may be able to use the same shifter but you will need a different attachment plate.
  3. Mr 4 Speed
    Mr 4 Speed Member
    1970 Grabber
    :rofl2: :biglaugh:
  4. kyle1972
    kyle1972 Member
    Modesto California
    1972 4 door Maverick 250 I6
    damn bro, just wondering...are you just tryin to start sh*t or be helpful?
  5. Joe Dirt
    From what I understand you have to have a install kit that's no longer avalible to be able to use a regular 4 spd shifter.
  6. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Either this "guy" has had a previous run-in with Paul and he's just found a new way to get revenge, or he's a complete a$$! Nearly every thread is a bash of some sort. :cry::cry::cry:
  7. supermav
    supermav Member
    clarkston wa.
    Thanks PaulS and Joe dirt for the response. as for mr 4 speed what is the problem? i asked for some help and got it. if you know something that they missed please do tell. if not listen to these guys and learn a thing or two. Play nice or don't play at all. Thanks again for the help . Todd
  8. Mr 4 Speed
    Mr 4 Speed Member
    1970 Grabber
    I didn't pick that screen name because it looked cool, ya' know. The Ford "3+1" transmission can use the same shifter but will need a different installation kit. You'll need to call Hurst. Go to this page.....
    http://www.hurst-shifters.com/s.nl/c.723089/sc.26/category.7326/.f
    ....and click on "4 speed manual transmission ID chart." Page 2 will show you the 3+1 transmission ID number (435). Find the transmissin ID that your current shifter came from then call Hurst and see if they have the kit you'll need. At the most you'll need a different mounting adapter along with shifter rods. The way Hurst is selling/packaging/marketing manual transmission stuff these days the only way to get an answer is to call them directly. Everything else is heresay.
  9. FordsForever
    FordsForever Member
    santa clara, ca
    74 mav
    Is that an SROD or the cast iron version that was used from 77 to 79? They have external linkage like early topoaders. Only the cast version can use a standard shifter like other 4 spd toploaders. If it's an SROD you need the ford shifter that's made for that trans. There are no aftermarket shifters for the SROD. Sources for the SROD are 80-83 mustangs, 80 and up Broncos and ford trucks from about 80 to about 89~approx. Granada/Monarch years unknown. Good luck.
    RS
  10. supermav
    supermav Member
    clarkston wa.
    it is the toploader style with the bump on the side for the o/d gear
  11. FordsForever
    FordsForever Member
    santa clara, ca
    74 mav
    That's quite the description of the trans. Doesn't tell me much. Is the 'bump' located on the right side about where the 3rd gear is on the inside?Got any numbers or a pic?
    RS
  12. PaulS
    It is the cast iron case. You can make the adapter plate from a piece of 3/8" aluminum or steel. You have to do some work to make sure the shifter is mounted at the correct angle and placed where it will go through the opening. It is not hard but it will take some careful work.
  13. Joe Dirt
    The bump is on the passenger side of the case and will have orion cast on the driver side
  14. FordsForever
    FordsForever Member
    santa clara, ca
    74 mav
  15. supermav
    supermav Member
    clarkston wa.
    sorry no pics. the boss is slow at getting things out of storage. he thinks he may still have the stock shifter but may take a while for him to come up with it. i still want to get a hurst shifter for it. i will post photos when i get it. yes it is the toploader imposter.
