What master cylinder?
Discussion in 'General Maverick/Comet' started by layne, Sep 28, 2010.
  1. layne
    layne Member
    Orlando, Florida
    70 Maverick, 70 Mach 1, 70 Cougar Eliminator
    Which master cylinder do i use for my 70 maverick? The car came with 4 drums but I have changed over to 4 disks, stock maverick fronts and lincoln versailles 9 inch rear with disks. Do I just use one for front disk and rear drum?
  2. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Use a master cylinder for car that came with 4 wheel disc. This way you get enough fluid to the rear calipers to puch the pistons out. It take more fluid to operate a caliper than a wheel cylinder. Master cylinders for disc brake cars usually have a larger bore diameter so they push more fluid towards the wheels as you press down the pedal.
    Try a versailles master cylinder or even a SN95 Mustang master cylinder.
  3. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    I used a '91 Ranger/Explorer master cylinder with a 1" bore for my 4-disc setup. (They also have a 15/16" bore; I chose the bigger one because I have a booster.) It works great. You'll need to change out the flare nuts on your lines or get adapters because the fittings on the MC are metric.
