What is this?
Discussion in 'Technical' started by streetrod77, Oct 3, 2005.
  1. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    What is this? What does it do? Can this be changed out for an aftermarket piece? I was thinking that is a computer brain or ignition box of some sort.:huh:
    The file is to large, I will have to get it smaller.
  2. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Okay I guess this will work.
  3. stmanser
    Davenport, Iowa
    it that GNDN.....
    Goes Nowhere Does Nothing...
    just kidding.... i cant see it to be honest... the wiring goes over the top of it....is there any wires going into it?
    the pic is so close.... try and get a dif picture....looks to me like near where the Starter Solenoid goes or maybe the voltage regulator?
  4. Earl Branham
    Lugoff, SC
    It is the ignition module for the DuraSpark ll ignition system.
  5. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    It'a FLUX CAPACITOR!!111one
    (Nanny-nanny-boo-boo! I said it fir-hirst! :bananaman )
  6. Earl Branham
    Lugoff, SC
    Needs 87 JiggaWatts to work!!!!!!!:rofl2:
  7. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I have to go home & check to see if there wires going to it. Here is a pic that's not so close.
  8. sierra grabber
    sierra grabber Certifiable
    northern nevada
    at least its for a ford, you wont have as much trouble hitting the 88mph:lolup:
  9. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    There will be two connectors on it .... one to your distributor and one to the wiring harness and coil. I recommend that you don't remove it ... :)
  10. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    So does the MSD 6AL box replace this box? I don't see any other pics with this box under there hood.
  11. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Yes the MSD 6AL will replace that box, and that is what I did. There is a way to wire it up so that you use both boxes, but I don't really understand the point of doing that. I mean, if you can do it, there has to be a point. :huh: Perhaps someone more educated can explain.
  12. Rick Book
    Rick Book Member
    Thailand
    I 'believe' it's so you can by-pass the MSD to troubleshoot electrical probs (by taking the MSD offline to see if it is the culprit).
    At least that's why the drag racers in my cricle have both systems.... maybe. :hmmm:
  13. Maverick Man
    California
    i have both connected on my yellow maverick... if MSD goes bad i can still run without it by, by passing it. trust me it will go out some day ;)
  14. 71gold
    i took it off...took it all off. i went with the ...pointless..."pertronix"...best $70 bucks i spent on the car...JMO...frank...:bouncy:
  15. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    yep what Frank said...pertronixs...good stuff...
