What is this piece of trim called?
Discussion in 'Cosmetic' started by Freelance Fury, Oct 31, 2011.
  1. Freelance Fury
    Freelance Fury Member
    Memphis, TN
    1971 Ford Maverick, inline 6
    Somewhere in the recesses of my brain, I know this. I really do! :hmmm:
    What is the name of the hard plastic pieces that run the length of this area on either side of the car? My Mav didn't come with them. When they were trying to get the carpet out, they didnt realize they had to take the metal strip out first in order to remove the plastic without cracking and breaking it. I want to find these pieces so I can go ahead and order the new carpet. But it's tough to find them when I can't think of the bloody name!
  2. Earl Branham
    Lugoff, SC
    Its called a sill plate. Gee, this is my 5,000th post! Doesn't seem possible, till I think it's been 12yrs!!!
  3. Freelance Fury
    Memphis, TN
    Ah, thank you! :bowdown: Now for phase two of the difficulty: finding some
    Congrats on your mile-marker! :thumbs2:
  4. mav1970
    It's been a long time since I stripped my car so my memory of bits and pieces is a little dim but isn't that a plastic cover just inside of the sill plate that covers some of the wire harness heading towards the rear of the car? :hmmm:
  5. Streamliner
    Streamliner Member
    Are Mustangs the same?....I know some of them are re-popped
  6. rwbrooks50
    rwbrooks50 Member
    Forney Texas
    71 Maverick & 63 Ranchero
    Yes it is. Some are cardboard.
  7. darren
    Isnt it a piece of cardboard and the carpet tucks over that edge and under the scuff plate??
  8. Freelance Fury
    Memphis, TN
    The guy I bought it from told me they were black plastic pieces and cracked when he was taking them out. I believe him, because the trim that runs behind and in front of this open section has little slots where the pieces would meet. At least, that's how it appears to me.
  9. Earl Branham
    Lugoff, SC
    Right you are....thought it was pointing to the sill plate. My apologies!:cry:
  10. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    The carpet goes over that area. You may need the "kick panels". They are forward of the rocker panels and under the dash (sorry don't have a pic right now).
  11. starsky74
    starsky74 Technician
    Hackberry Louisiana
    wooooooooooooooooooooooooooooooooooooooo:clap:
  12. Craig Selvey
    Looks to me like the original cardboard is still there.
    I have only found plastic ones on 1970 Mavericks.
    I have both cardboard and plastic ones available if needed.
  13. Freelance Fury
    Memphis, TN
    Its tough to explain it via computer. Damn you, technology! You can look in front of it and see the kicker panel, yes? There's a little open slot in it where it seems a corresponding connecting piece of trim would go. I havent seen many interiors on these cars pre-restoration, so I'm not stating that with certainty. It just doesn't look 'right' as just the cardboard there, plus the guy said he took something out (unless he was mistaken. He had several cars sitting on his property)
  14. Craig Selvey
    The only things you are missing that would cover up the cardboard and that hole at the front is:
    1. Front kick panel
    2. Carpet
  15. darren
    You need a carpet. Your kick panel is intact looking at the pic. Craig is right your cardboard is still intact as well. The end of your kick panel tucks under the scuff plate like yours is. The carpet will fill in all the rest.
