What is this for?
Discussion in 'General Maverick/Comet' started by William623, Jan 14, 2016.
  1. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    image.jpeg I have wondering for awhile, what is the purpose of this thing? I can't think of any good answers.
  2. Craig Selvey
    It only came on cars with radio. Supposed to be a "ground" for the hood.
  3. William623
    William623 Member
    Orlando
    Thank you, I have been curious about that for awhile!
  4. 71gold
    " Supposed to be" is the general opinion. we still don't know what it does. hood hindges and latch do the same thing in my opinion so....:huh:
  5. Craig Selvey
    I have seen this included with NOS radio kits....so FoMoCo must have thought it would do something.
  6. 71gold
    another one of..."Fords better ideas"
    am I the only one that has taken it off?
  7. x72COMETx
    x72COMETx Member
    Vallejo CA
    X2 removed mine also
  8. Craig Selvey
    I restored mine and but it back on. Cleaned up great with some ketchup.
  9. Paul Masson
    1971 Grabber
    Me too...
  10. Krazy Comet
    Yes it is a hood ground, the copper doesn't rust and "teeth" dig into metal to provide ground(at least in theory)... Does it make a difference?? Probably not on FM but definitely improves AM, especially if you lived in the boonies and only stations were several miles away... Remember in the late '60s/early '70s FM was only beginning to rival AM as the preferred medium... FM didn't really start to clobber AM till the high power FM stations were signing on(ones with 500-1000ft towers, got our first in '73)... Prior if you were 20-25 miles from a FM, it was done...
    The hinges will provide a intermittent ground at best... Likely OK when new, but a little wear or rust and the electrical integrity is badly compromised...
    Craig Selvey likes this.
  11. 71gold
    could someone check and see if they left an unpainted spot for this to ground through...:huh:
  12. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    Yes. It really works.
    Because the hood latch and hinges do not make a "perfect" ground connection, wind blowing over the hood on a dry day (humidity very low), can cause static build up. In addition, the ignition system generates electric and magnetic fields, too. - all causing a difference in potential between the hood and auto body.
    The radio used the car body as a ground plane. The build-up & discharge of electricity can cause noise on a radio.
    Typically, though - noise is most pronounced in the AM band.
  13. Craig Selvey
    Grounding is done via the screw. The threads of the screw will ground on the back side (inside) of the cowl. Same with the voltage regulator, starter solenoid, and inside wiring harness (it is grounded with a screw to the painted dash) and other electronics on the car.
  14. 71gold
    sooooo why are we grounding the other end to a painted surface...:huh:
  15. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    What does the hood have to do with the radio antenna?
    71gold likes this.
