What gears are you running?
Discussion in 'General Maverick/Comet' started by paperboy, May 12, 2014.
  1. paperboy
    paperboy Member
    Northern Indiana
    1977 maverick
    Looking at gear options for my stock (for now) 1977 250 with the c4. I do the majority of my driving around town with some highway. If I drive at 60mph it's usually for only about an hour at a time. Also, my tires are 235/60/14.
  2. Acornridgeman
    Wisconsin
    You don't say what you want to accomplish.
    Better mileage? 2.79
    Snappy performance and still have some mileage? 3.25- 3.55
    Total stop light runner 3.80
    :chirp:
  3. paperboy
    paperboy Member
    Northern Indiana
    1977 maverick
    Wanting more off the line snap, but not completely kill my mileage. Is there a big difference between 3.25 and 3.55?
  4. Acornridgeman
    Wisconsin
    Using your tire size, 60mph and a 1:1 final transmission ratio:
    3.25 = 2595 RPM
    3.55 = 2834 RPM
    For comparison, stock 2.79 = 2228 RPM
    :Handshake
  5. z28th1s
    Lynchburg, VA
    I have 3.40 gears in my '72 Grabber, but I'm running a 27" (255/60/15) tall tire on the rear. I like that gear, though it really needs a lower gear to make it impressive off the line with my mods.
  6. paperboy
    paperboy Member
    Northern Indiana
    1977 maverick
    Well, it looks as if the 3.55 is a good all-around gear and still keeps rpms at reasonable highway levels.
  7. z28th1s
    Lynchburg, VA
    3.55's are harder to find used and you usually have to pay more for them. I wanted 3.55's for my car, but 'settled' for the 3.40's.
  8. rthomas771
    I swapped my 2.79 to a 3.00 to 1. It made a lot of difference on the low end and even helped a little in the MPG's. I'm still using the 3.00 with my t5. I have 235x15" tires. I'm thinking 3.55 might be too much gear. I had a 3.70 under my Falcon with 215x15" and I had to turn 3800-4000 to keep up with everybody on the interstate. It now has a 3.25 and turns about 3200 on the interstate
  9. paperboy
    paperboy Member
    Northern Indiana
    1977 maverick
    Do the 3.40's work good for you?
  10. z28th1s
    Lynchburg, VA
    Yes they do. My car is a 302 though. My car turns about 2,550 RPM's at 60 MPH with my gear/tire combo.
  11. paperboy
    paperboy Member
    Northern Indiana
    1977 maverick
    Would my car with the 235/60/14's run a little bit higher?
  12. z28th1s
    Lynchburg, VA
    According to the tire calculator on tires.com my 255/60/15's are 27.05" tall. Your 235/60/14's are 25.1" tall. That means your tires are right at 2" inches shorter which will make your highway RPM's quite a bit higher than mine with the same rear end gear.
  13. paperboy
    paperboy Member
    Northern Indiana
    1977 maverick
    What gear would you suggest? I would like to keep my RPMs under 3,000 at highway speed. I figure anything more than the 2.79's I have will be a big difference. Don't want to be a pest, just trying to learn all I can. Wealth of knowledge on this site!!!
  14. z28th1s
    Lynchburg, VA
    Plugging your info into the Summit Racing gear ratio calculator comes out to this.
    3.55's = 2,850 RPM's at 60 MPH
    3.40's = 2,730 RPM's at 60 MPH
    3.25's = 2,610 RPM's at 60 MPH
    3.00's = 2,410 RPM's at 60 MPH
  15. Acornridgeman
    Wisconsin
    On my calculations, I over inflated the tires to 25.25" ................... :biglaugh:
