what fuse is what?
Discussion in 'General Maverick/Comet' started by mavmanerick, Aug 17, 2007.
  1. mavmanerick
    royal city, washington
    i want to hook up a cigarette lighter/phone charger thing in my car but i dont know which fuses are what.. which fuse do i hook it up to?
  2. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    And where do I get another teeny weeny lil one at?
    Is there a fuse diagram?
  3. mavmanerick
    someone posted a fuse diagram on here awhile back and i copied it to my pics but when i finally wanted to refer to it, it only copied the diagram for 74 and up or something.. i need the one for 1972..
  4. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I would tap off the current cigarette lighter fuse. Hot all the time. I cant get to my 72 to tell you what fuse it is. I always tap off the dead side of the fuse just in case. Then I still put an inline fuse in.
    Dan
  5. timers
    timers Member
    richardson tx
    1974 maverick
    on my 75 its the hazad flasher, cigar? lighter fuse # 1 (20 amp.) top left on the fuse panel
  6. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Unless your worried on looks, I would run a seperate wire from Battery side of solenoid (protect with a in-line fuse) an hook up power plug
  7. timers
    timers Member
    richardson tx
    1974 maverick
    if you dont have a sig lighter in your car now there is a wire for it back there
  8. mavmanerick
    sweet ill check it out tomorow..:)
  9. CaptainComet
    Cig lighter wire
    It is pretty common for stereo guys to use that wire for constant power so that clocks and presets stay on, so that may be another clue. Unless I am thinking of another car, I believe the end of the wire has a 90 degree rubber insulator on the end, and the fitting on it is made to slip onto a bolt that projects out of the lighter.
  10. scooper77515
    I just posted the fuse diagram a couple weeks back...
  11. PAINTANK
    1973 Comet 2 dr
    Cool.
    I had to reinstall my lighter when I got my 73(weird cause I don't smoke). It was simple and the power was a wire with a rubber L on the end.
  12. mavmanerick
    i popped off the cap to access the hole for the cigarette lighter and there is a black wire back there but it is connected to something..:hmmm:
  13. MissMaverick
    MissMaverick Just a girl who luvs Mavs
    Michigan
    1970 Grabber, 1977 Maverick
  14. mavmanerick
    cool, i thought theyd be gone cause he said he was gonna delete them..(y)
  15. PAINTANK
    1973 Comet 2 dr
    Swiped and on my PhotoBucket account for all eternity.
    Thanks!
