What could be wrong?
Discussion in 'General Maverick/Comet' started by alaskamaverick, Jul 31, 2013.
  1. alaskamaverick
    alaskamaverick Member
    Spokane, WA
    I bolted the tranny to the engine and tried to turn the engine via socket/ratchet and it wont budge? :hmmm:
    And no...I don't need to go to the gym, used 1" drive socket/ratchet.
  2. yellow75
    Tillamook Oregon
    Sounds like you did not get the torque converter all the way in the tranny, or you did not match up the drain bolt in converter with the flex plate.
    Did you have to pull the tranny in to meet block with the bell housing bolts. Another thought I noticed in another post that you said you changed from a manual tranny to and automatic, did you remove the pilot bearing in the crankshaft that the manual tranny input shaft went in ?
  3. alaskamaverick
    Spokane, WA
    "or you did not match up the drain bolt in converter with the flex plate."
    Please do explain
    I converted the steering column 3 on the tree to a floor shift, both the tranny and engine were originally automatic out of the same vehicle
  4. yellow75
    Tillamook Oregon
    Sorry in the post that I read you were referring to the hole for clutch rod and you stated that you changed to and automatic so I assumed you changed from a manual tranny to an automatic.
    In the flexplate there is a hole that allows for the drain plug that most converters have to fit through.
    What engine are we dealing with?
  5. alaskamaverick
    Spokane, WA
    Lincoln continental 5.0/302
  6. yellow75
    Tillamook Oregon
    Try loosening the bell housing bolts and give the tranny a little free play from engine and see if it will spin.
    When torque converter is installed correctly you should have like 1/8" of free play between torque converter and flexplate before putting the four torque converter bolts on.
  7. alaskamaverick
    Spokane, WA
    OK, I'll give it a try tomorrow night. I appreciate the help.
  8. 55crownvic
    55crownvic Member
    colorado springs
    This happened to me on my last mav when I was installing an AOD, got the wrong flexplate, it was binding with the converter, took a good while to figure that one out.
  9. alaskamaverick
    Spokane, WA
    yellow75, I sent you a PM
  10. alaskamaverick
    Spokane, WA
    55 crownvic, I used all of the old parts that came out/off
  11. yellow75
    Tillamook Oregon
    PM replied to
  12. alaskamaverick
    Spokane, WA
    Another PM sent
  13. 71gold
    PM sent...
  14. alaskamaverick
    Spokane, WA
    To those that have been following, the problem is that I installed the torque convertor incorrectly. I installed the flex plate to the crank, then installed the torque convertor to the flex plate, then bolted the tranny to the engine block...:banghead:
    I'll take things apart tonight...and thanks for the help from yellow75 and 71gold
  15. simple man
    simple man Member
    Bunnell,Florida
    Make sure to replace the front pump seal! It likely got destroyed in the process! :D
