What can I take from this 1974 Mustang II Parts Car?
Discussion in 'Parts Interchange' started by lpolson07, May 14, 2010.
  1. lpolson07
    lpolson07 Member
    Des Moines
    76 Maverick, 72 Comet
  2. justin has a 74
    kentucky
    Im thinking mustang 2 suspension (look up details in the search box)
  3. maverick75
    Floor shifter, also check the rear end. Those came with 8".
    here's how to decode them:
    http://www.mustangii.org/decoder/axle/
    the bad news is that in 74 they did not come with the track-lok.
    the stock MII suspension is not really desirable, its the aftermarket MII kits that are..
  4. scooper77515
    For that price, if it was ANYWHERE near me, within a days drive, I would haul it home and pull the front end out.
  5. rthomas771
    Like maverick75 says, trying to make a Mustang II suspension to work in any car would require a lot of work. You will end up with more time and money than buying a rack & pinion kit.
  6. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I wonder why you couldn't use the factory front end pieces on an aftermarket crossmember? That is, unless they are worn out, then the only gain would be the spindles. You could adapt the seats and shifter to a Mav pretty easily.
