I have a non-tapered 9 inch axle shaft. It looks like any u-bolt with a inside dimension of 3 inches, 1/2 inch dia and 7 inches long should work. Is this about right?
you are on the right track. you should be able to slot or over size the holes in the stock spring plate to accommodate the bigger u bolts.
